Washing Machine Water Surge - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2009, 04:44 PM   #1
washing machine water surge
The town I live in has septic tanks. OUr washing machine was connected to a separte pit. In the winter when the water table is high we get a splash back. Is there any way to prevent this?
nanad is offline   Reply With Quote
Old 08-22-2009, 05:50 PM   #2
Rewards Points: 1,440
If your pit is too close to the surface, the ground could be frozen and not perc in winter. High water table also slows the perc rate. Then the pit stays filled up for a long time and the drains connected to it back up.
Is a larger pit feasible? Just so more water can be held and you can do more washloads in a row before the pit overflows. (You'll still have to wait until the water soaks into the ground.)
Old 08-22-2009, 08:07 PM   #3
washing machine surge.
The pit is pretty deep. If I stop the machine as it spinning the water does flow. I'm trying to slow down the water flow.into the out pipe
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Cold water hose - washing machine cmcgowan Plumbing 1 01-08-2009 11:13 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
