Washing Machine Valve - How To Replace? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2012, 07:08 AM   #16
Rewards Points: 2,516
Here is a ball valve one taken apart:
Only leak sources would be the white plastic seat under the hose adaptor or the O-ring on the 1/2" MIP threaded stem.
washing machine valve - how to replace?-img_0001.jpg   washing machine valve - how to replace?-img_0003.jpg
hammerlane is offline   Reply With Quote
Old 12-04-2012, 11:31 AM   #17
Special User
Rewards Points: 1,230
Originally Posted by DIYGST View Post
when I remove the packing nut would it help to use another wrench to hold the bottom nut.. or.. (where else?) to avoid stressing the piping
YES!
My washing machine valves had the same issue. I replaced mine without holding back with a second wrench. Everything for fine for a few months until blam, one night the solder joint at the bottom of one of those pipes let go and dumped a bunch of water into the crawlspace. I'm convinced that I weakened the joint, and created a ticking time bomb.
So yes, always avoid stressing the pipe. The damage you cause may show up later at the most inopportune time.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
What kind of arrester to get for washing machine water hammer Rav Plumbing 4 09-09-2012 10:36 PM
Washing machine wall valve dmarsh Plumbing 0 03-10-2012 11:18 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
washing machine supply valve leaking tina2435 Plumbing 9 01-24-2009 04:17 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
