Washing Machine Valve - How To Replace? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2012, 04:17 PM   #1
Rewards Points: 278
washing machine valve - how to replace?
these are leaking..
I plugged up the outlet then the water is coming out of the handle.
Any idea if this is a pipe thread valve or not, I looked under the face plate and see a series of threads.
do I need to remove drywall?
DIYGST is offline   Reply With Quote
Old 12-03-2012, 04:30 PM   #2
It'd be easier to just replace the 50 cent washers in the two valves.
Ishmael is offline   Reply With Quote
The Following User Says Thank You to Ishmael For This Useful Post:
DIYGST (12-03-2012)
Old 12-03-2012, 04:42 PM   #3
Rewards Points: 278
would that be the guts under the packing nut you are talking about?
I see they already tightened the packing nut a bunch on the hot side probably to stop things from leaking.
Old 12-03-2012, 04:59 PM   #4
Correct.
That depends on where they're leaking from. Are they leaking around the handles/stems? Then, yes, tighten the packing nuts. Or are they leaking from the actual water outlets (where the hoses screw on). If that's the case, then tightening the packing won't do anything productive. You'd have to replace the washers.
Old 12-03-2012, 05:06 PM   #5
Rewards Points: 278
it is leaking at the outlet,
I bought a garden hose cap to close it up, thinking this "leak" doesn't matter once I get my washing machine, but then the water started to go out the top when I did this.
So both the packing and seal lets water thru. It's a hot washer valve so I think it is quite common for this deterioration.
should I have it replaced with a ball valve? This valve is 23 years old.
Old 12-03-2012, 05:12 PM   #6
Rewards Points: 13,300
Cheaper to just replace the washer and repack the stem.
Old 12-03-2012, 05:12 PM   #7
I'd try the easy fix (washer) before replacing the whole valve. It's 23 years old, but there's no reason it can't last another 23 years.
Old 12-03-2012, 05:19 PM   #8
Rewards Points: 278
where do I find the packing and washer for it?
Will it be in here?
http://www.lowes.com/pd_31461-1366-8...%7C1&facetInfo=
Old 12-03-2012, 05:30 PM   #9
Lowes Home Depot, any plumbing supply store, any hardware store.
You will need to shut the water off and remove the washer to find a replacement. There's dozens of differant sizes.
DIYGST (12-03-2012)
Old 12-03-2012, 05:32 PM   #10
Rewards Points: 278
just 1 more question for now..
when I remove the packing nut would it help to use another wrench to hold the bottom nut.. or.. (where else?) to avoid stressing the piping is the bottom nut just there to hold it against the plastic box
Old 12-03-2012, 05:38 PM   #11
Rewards Points: 278
Do I have to shut off the hot water heater valve after shutting off the house supply valve in order to repair the hot side?
Old 12-03-2012, 07:21 PM   #12
Plumber
TheEplumber's Avatar
Rewards Points: 452
No, once you kill the house valve you're good on the hot too. It wouldn't hurt to turn off the power/fuel source at the heater as well. Relieve the pressure before tearing into the valves and always use a back up wrench. Take the stem to your local supplier, buy replacement parts and your good to go
The Following User Says Thank You to TheEplumber For This Useful Post:
DIYGST (12-03-2012)
Old 12-03-2012, 09:26 PM   #13
Rewards Points: 278
Got the stem off the screw holding the seal washer is looking to be a tuff one
White crud on the Philips screw head but I'm afraid it might strip
Any tips?
Old 12-03-2012, 11:29 PM   #14
Clean out the crud, make sure your using the right sized bit.
I use an impact screw gun.
http://www.bing.com/shopping/18v-imp...iver&FORM=HURE
Old 12-04-2012, 07:31 AM   #15
Rewards Points: 2,516
I had a single handle Oatey washing machine valve that leaked. Here is the thread:
Leaking Oatey washing Machine Shutoff Valve
hammerlane is offline   Reply With Quote
What kind of arrester to get for washing machine water hammer Rav Plumbing 4 09-09-2012 11:36 PM
Washing machine wall valve dmarsh Plumbing 0 03-10-2012 12:18 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
washing machine supply valve leaking tina2435 Plumbing 9 01-24-2009 05:17 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
