-   -   washing machine valve - how to replace? (http://www.diychatroom.com/f7/washing-machine-valve-how-replace-165497/)
DIYGST 12-03-2012 04:17 PM
1 Attachment(s)
these are leaking..
I plugged up the outlet then the water is coming out of the handle.
Any idea if this is a pipe thread valve or not, I looked under the face plate and see a series of threads.
do I need to remove drywall?
Ishmael 12-03-2012 04:30 PM
It'd be easier to just replace the 50 cent washers in the two valves.
DIYGST 12-03-2012 04:42 PM
would that be the guts under the packing nut you are talking about?
I see they already tightened the packing nut a bunch on the hot side probably to stop things from leaking.
Ishmael 12-03-2012 04:59 PM
Correct.
That depends on where they're leaking from. Are they leaking around the handles/stems? Then, yes, tighten the packing nuts. Or are they leaking from the actual water outlets (where the hoses screw on). If that's the case, then tightening the packing won't do anything productive. You'd have to replace the washers.
DIYGST 12-03-2012 05:06 PM
it is leaking at the outlet,
I bought a garden hose cap to close it up, thinking this "leak" doesn't matter once I get my washing machine, but then the water started to go out the top when I did this.
So both the packing and seal lets water thru. It's a hot washer valve so I think it is quite common for this deterioration.
should I have it replaced with a ball valve? This valve is 23 years old.
joecaption 12-03-2012 05:12 PM
Cheaper to just replace the washer and repack the stem.
Ishmael 12-03-2012 05:12 PM
I'd try the easy fix (washer) before replacing the whole valve. It's 23 years old, but there's no reason it can't last another 23 years.
DIYGST 12-03-2012 05:19 PM
where do I find the packing and washer for it?
Will it be in here?
http://www.lowes.com/pd_31461-1366-8...%7C1&facetInfo=
joecaption 12-03-2012 05:30 PM
Lowes Home Depot, any plumbing supply store, any hardware store.
You will need to shut the water off and remove the washer to find a replacement. There's dozens of differant sizes.
DIYGST 12-03-2012 05:32 PM
just 1 more question for now..
when I remove the packing nut would it help to use another wrench to hold the bottom nut.. or.. (where else?) to avoid stressing the piping is the bottom nut just there to hold it against the plastic box
DIYGST 12-03-2012 05:38 PM
Do I have to shut off the hot water heater valve after shutting off the house supply valve in order to repair the hot side?
TheEplumber 12-03-2012 07:21 PM
No, once you kill the house valve you're good on the hot too. It wouldn't hurt to turn off the power/fuel source at the heater as well. Relieve the pressure before tearing into the valves and always use a back up wrench. Take the stem to your local supplier, buy replacement parts and your good to go
DIYGST 12-03-2012 09:26 PM
Got the stem off the screw holding the seal washer is looking to be a tuff one
White crud on the Philips screw head but I'm afraid it might strip
Any tips?
joecaption 12-03-2012 11:29 PM
Clean out the crud, make sure your using the right sized bit.
I use an impact screw gun.
http://www.bing.com/shopping/18v-imp...iver&FORM=HURE
hammerlane 12-04-2012 07:31 AM
I had a single handle Oatey washing machine valve that leaked. Here is the thread:
http://www.diychatroom.com/f7/leakin...-valve-122780/
