Old 02-09-2012, 07:49 PM   #16
Washing Machine Supply Valve Leak.
Originally Posted by hammerlane View Post
I took the valve assembly fully apart. Below are the photos:
Parts for reference:
A: valve body
B: ball valve
C: white plastic seat(one in front of and behind ball valve)
D: hose adaptor
E: we'll call this ball stem
To get to the washers on the ball stem you have to:
-remove the hose adaptor(D),
-remove the front white plastic seat(C)
-then align the ball valve(B) in the proper orientation with the keyway to pop the ball valve out
-then you can remove the ball stem to replace washers.
Yes, that means that there are 3 potential leak points..not two.
handy man88 is offline   Reply With Quote
Old 02-09-2012, 11:10 PM   #17
handyman do you mean 3 potential leaks points overall or 3 potential leak points for the original poster?
The original poster said his leak is at #3. look at his first post and look at #3 on his photo. If his leak is at #3, then his leak is coming out the male hose adaptor. Which means the white plastic seat is bad or not seated properly.
If the stem valve o-rings were bad, his leak would be coming out from under the handle.
If the o-ring at the top of the 1/2 MIP threaded stem was bad, the leak would be directly below this o-ring shown at point #5 in the first photo.
hammerlane is offline   Reply With Quote
Old 02-09-2012, 11:45 PM   #18
I was just responding to one of your original posts where you identified only 2 potential leak points and I included another one.
"Only leak sources would be the white plastic seat under the hose [COLOR=blue !important][COLOR=blue !important]adaptor[/COLOR][/COLOR] or the O-ring on the 1/2" MIP threaded stem."
Old 02-10-2012, 12:05 AM   #19
Yeah you're right.
From my post #12 I only said the o-ring at the base of the threaded stem or the white plastic seat.
That was before I dissambled the ball stem and found the o-rings on it
Old 02-10-2012, 05:34 PM   #20
Yeah you're right.
Not to pat myself on my back, but I knew there would be a seal there because the stem is a moving/rotating part.
Old 02-10-2012, 06:17 PM   #21
Like a little puzzle trying to get it all taken apart.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
washing machine shutoff valve - advice needed... myke232 Plumbing 11 11-27-2011 07:51 AM
Dripping washing machine connection icespide Plumbing 4 11-11-2010 09:41 PM
Replacing Corroded Washing Machine Valve pjrcard Plumbing 3 09-13-2010 06:47 PM
Washing machine - hot water supply only? Sosh Plumbing 4 07-11-2007 04:36 PM
