Washing Machine Standpipe Height - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2012, 09:44 AM   #1
washing machine standpipe height
Hi All, In the process of moving laundry from basement to first floor. Without a great deal of work I am 27" from laundry box to trap. Trap will then discharge through concrete wall back into basement and then drop of 4-5 feet. I understand that the 27" is probably not enough but with the drop beyond the trap am I ok?
Thanks in advance for your advice, pros only please.
white29 is offline   Reply With Quote
Old 01-14-2012, 09:45 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is it vented?
Journeyman Plumber
Old 01-14-2012, 09:49 AM   #3
Yes, I wiil be using a Studor Vent.
Old 01-14-2012, 09:50 AM   #4
Doing it myself
Alan's Avatar
P trap for a washing machine between 6" and 12" off the floor. Standpipe no less than 18" and no greater than 30"
This is Oregon code.
Journeyman Plumber
Old 01-14-2012, 09:50 AM   #5
And it's 2" pipe.
Old 01-14-2012, 09:53 AM   #6
Thanks. I'm hearing all the same for here in NY, but also hearing a lot about standpipe height of 33-36". Keep in mind the drop I have beyond the trap.
Old 01-14-2012, 10:03 AM   #7
jproffer's Avatar
Rewards Points: 718
The height has nothing to do with the drop below the trap. It's to keep the water in the washer
Should say in the washing machine manual how tall they recommend.
jproffer is offline   Reply With Quote
Old 01-14-2012, 11:17 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 924
Where exactly is the vent going?
Old 01-14-2012, 01:02 PM   #9
Vent will be inside wall cavity . This is a 4 by 4 removable ply wood panel. studor type vent probaly 20" or so above trap weir.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Washing machine discharge hose Deck Plumbing 7 01-14-2012 08:15 PM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 10:51 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 08:02 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
