Washing Machine Shutoff Valve-repairable? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2010, 09:15 PM   #1
Rewards Points: 262
Washing machine shutoff valve-repairable?
I'm thinking I'm just going to have to replace this but it seems there should be a way to repair it. This looks most like the valve I have.
I took the inner nut out that turns with a large hex key expecting to find a replaceble O-ring but did not find one. I don't know the brand but do know it is not a Watts since they are clearly labeled. Any ideas before I cut and replace?
Jim F is online now   Reply With Quote
Old 07-09-2010, 11:58 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Those are just quarter turn ball valves. They should last a really really REALLY long time. What's wrong with it?
Journeyman Plumber
Old 07-10-2010, 11:19 AM   #3
Rewards Points: 262
You cant turn it off all the way. The cold leaks a little.
Old 07-10-2010, 11:40 AM   #4
Doing it myself
Alan's Avatar
It should just be a stainless ball with a teflon seal, AMIRITE?
Don't think you can fix them that I know of.
Journeyman Plumber
Old 01-01-2011, 02:44 PM   #5
Are most of these shut-off valves interchangeable?
I have the valve exactly as shown, but I don't know who makes it (? Watts).
The question is: If I buy a Mueller Valve from Home Depot and just transfer the top over, is it fine. Example of HD Valve:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
cn90 is offline   Reply With Quote
Old 01-01-2011, 03:05 PM   #6
Household Handyman
Rewards Points: 1,408
"Jim F", you could use the theory I use, and I use it a lot: IF someone put it together, then someone can take it apart to see if it can be repaired. So you get it apart and can't repair it-you were looking at buying a new one anyway, weren't you?
The bottom line here, at least with me, would be to replace it--then take this one apart to become a PHD in "Laundry Faucet Repair".
Old 11-25-2011, 11:45 AM   #7
Rewards Points: 2,512
I see this is an old post. If you are interestes I had same problem and started a thread here and was able to put pictures of the valve taken apart:
http://www.diychatroom.com/f7/leaking-oatey-washing-machine-shutoff-valve-122780/
hammerlane is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
washing machine shutoff valve - advice needed... myke232 Plumbing 11 11-27-2011 07:51 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
washing machine supply valve leaking tina2435 Plumbing 9 01-24-2009 05:17 PM
