Washing Machine Shutoff Valve - Advice Needed... - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2009, 09:47 AM   #1
Rewards Points: 28
washing machine shutoff valve - advice needed...
Hello,
I have a slightly leaky washing machine shutoff valve that I would like to replace. My question is, can I replace my existing one without doing any soldering? My hope is that I could remove the 2 big flat-head screws in front, hopefully the unit would slide off, and I could then screw a new one on. The problem is I don't know how this thing comes apart exactly. Does anyone know? Pics provided... Thanks!
washing machine shutoff valve - advice needed...-shutoff_1.jpg   washing machine shutoff valve - advice needed...-shutoff_2.jpg   washing machine shutoff valve - advice needed...-shutoff_3.jpg
myke232 is offline   Reply With Quote
Old 11-01-2009, 06:37 AM   #2
It is leaking at the shaft of the control lever. I have never had one of those apart before, but from the amound of rust I see, I would replace the whole thing. You could spend a lot of time taking it apart and then find it can't be repaired.
Old 11-01-2009, 07:05 AM   #3
http://www.accentshopping.com/product.asp?P_ID=148753
this might help you, I don't know if this is your model or not but should get you started anyway, they have repair parts and a diagram to look at, happy plumbing.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 11-01-2009, 07:22 AM   #4
Rewards Points: 28
Thanks guys.
Actually, my plan is to replace the whole thing. I'm just trying to find out if I can do so without soldering anything. Does the valve unit include everything up to and including the soldering where it meets the water lines; I guess that is the main question.
Cool, yeah I found that too, although I'm still not 100% sure where the actual valve ends and the water lines begin.
I was hoping someone would have experience with the valve and would know exactly what needs to be done; most importantly soldering vs. no soldering...
Old 11-01-2009, 08:00 AM   #5
How To Solder Copper Pipes
Take a look through this thread, You can do it! Not to expensive to get started with the equipment needed..You can practice on some scrap pieces beforehand. Looking at the pics, you can see when the last guy soldered, it blackened the wood some, that will happen because of location, just have a bucket of water and a big rag near you. You're going to feel so good about yourself after you complete this,, good luck, and there are lots of people here to help you.
LIVING THE DREAM
Old 11-25-2011, 10:44 AM   #6
Rewards Points: 2,516
I see this is an old post. If you are interestes I had same problem and started a thread here and was able to put pictures of the valve taken apart:
Leaking Oatey washing Machine Shutoff Valve
hammerlane is offline   Reply With Quote
Old 11-26-2011, 06:44 PM   #7
Rewards Points: 582
yes its done all the time...get new valve same kind take screws off be careful o rings ...put new valve in replace screws.... make sure to turn off water
Old 11-26-2011, 07:39 PM   #8
Thats easier said than done.
In my situation I could not find the exact same valve that I have now. The one that Oatey manufactures now has different size taps so the new valve body will not fit on the existing taps I have in my washer box once I take the old valve body off.
Only remedy is cut open wall, cut out old taps and solder in new.
The Following User Says Thank You to hammerlane For This Useful Post:
ben's plumbing (11-26-2011)
Old 11-26-2011, 09:17 PM   #9
Rewards Points: 582
yes that can happen but most of the time it works out....watts is what is changed the most.....don't know what you had...some times the neck where set against o rings is alittle longer.... good thought..
Old 11-26-2011, 09:59 PM   #10
Thats what the problem was...the taps on the new are larger both in length and diameter.
washing machine shutoff valve - advice needed...-100_7376.jpg   washing machine shutoff valve - advice needed...-frfef.jpg
Old 11-26-2011, 10:03 PM   #11
Rewards Points: 582
who made your old valve watts, oatly...or some import....thats what happens when we don't stay with name brand supplies.....sorry to here you had trouble.....I never did...
Old 11-27-2011, 06:51 AM   #12
You looked at my other thread I posted on my leaking Oatey valve. If you can find one identical I'll praise your name.
Here is my post on my valve:
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 01:25 PM
Washing Machine Drain mqcarpenter Plumbing 3 11-20-2008 07:47 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Washing Machine compression valve leaking...HELP! tmcguirk Plumbing 12 04-17-2008 08:16 AM
