Amazing!! Another house bought without a presale inspection. Also plumbed by I can glue pipe so I am a plumber. You have Black glued to White Bad sign.... Tee on it's side picking up something.
We can gut your house later..
You need to purchase the following.
A laundry tray
A Low profile drain sump
http://www.rakuten.com/prod/compact...t&adid=18172&gclid=CLGr-qavsb0CFYZAMgodsx0ArA
Install Laundry tray great for when we fix the rest of the plumbing.
Washer goes to Laundry tray
Laundry tub drains to bucket sump
Bucket sump gos to 4 inch all by itself.
You will also need
A 4 inch PVC thread by glue connector
http://www.rakuten.com/prod/1-2-pvc...e&adid=18172&gclid=CPb3yJKwsb0CFbFaMgodwncAvQ
4 by 2 PVC Wye
http://www.rakuten.com/prod/genova-...e&adid=18172&gclid=CPOcpaawsb0CFfFFMgodPUwA7Q
2 by 1.5 inch bushing
A few 1.5 inch PVC fittings
1 sump check valve 1.5 inch
1.5 inch PVC pipe
4 inch PVC pipe
PVC Glue And PVC Primer
Now from the cute bucket sump y tie in the pvc to the pump it gos to the new 4 inch wye you just installed looking up in front of that used to be clean out.
The brass cleanout plug is removed the 4 inch threaded adaptor with dope and tape screws into it the wye glues into that
A 4 inch cleanout installed in the other side of the wye with a plug
Bush down the 2 inch of the wye to 1.5 inch
It runs to the sump with that nice new 1.5 inch sump check installed above the pump.
Just run the sump vent up to the joist and turn down with 2 90's
About 4 hours of work when you know how.
