Washing Machine To Main Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-23-2013, 05:32 PM   #1
Washing machine to main line
I had a washing machine on other side of house that was running into a drywell. The drywell always get clogged and causes headaches. House is on a slab and can't dig up house. Ran PVC underground along side and in front of home to the main line. Tapped into main line and seems to drain fine. The line from washing machine to the main has no vent.. Is it possible to just use p-trap without vent?
Robv81 is offline   Reply With Quote
Old 12-23-2013, 06:30 PM   #2
Rewards Points: 608
anything is possible... .but the real question is...was the line installed right and up to the plumbing code for your area and was it inspected....Iam guessing no.. sorry..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Robv81 (12-23-2013)
Old 12-23-2013, 06:36 PM   #3
Rewards Points: 2,410
I can glue pipe so I'm now a plumber.... Would you hire me to fix your car I can turn a wrench also. I also can do brain surgery I have a big drill and rubber gloves....
The answer is by code it should be vented but if your good with the smell of sewer I'm good I can't smell it here.
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
Robv81 (12-23-2013)
Old 12-23-2013, 07:13 PM   #4
Rewards Points: 1,632
Attachment does not work.
Old 12-23-2013, 11:07 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 852
hey Ghost stop using my quotes OK.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-24-2013, 02:39 PM   #6
Plumber/Contractor
TheEplumber's Avatar
Rewards Points: 3,116
Robv81- Previous post deleted-- You can have an unvented trap- however, it is not legal, will not function right. Your inspector would catch that.
Old 12-24-2013, 03:16 PM   #7
Could I use one of those automatic vents instead of running a vent stack through the roof?
Old 12-24-2013, 10:03 PM   #8
Not in Ohio. You need to call your local building department and ask.
Old 12-24-2013, 10:09 PM   #9
I'm impressed Javiles looks like your running a honest company. I hated it when I worked for some of the not so honest. I always ended up leaving for other opportunities.
Washing Machine into utility sink help JASON MARTIN Plumbing 10 01-07-2013 09:01 AM
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 01:07 PM
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 11:51 AM
De-soldering main water line MikeKy55 Plumbing 15 01-29-2011 02:39 PM
Washing machine below septic line. Sellwithnic Plumbing 3 01-05-2011 09:40 PM
