Washing Machine Hot Pipe Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2013, 08:30 AM   #1
Washing machine hot pipe leaking
Hi All, I am having a crazy time getting this new washer / dryer to work. After fixing the electrical issue with my dryer I now have the hot water pipe leaking. I hope the attached picture will help see my issue and someone may be able to help me fix it.
Thanks,
wololo696 is offline   Reply With Quote
Old 01-07-2013, 08:43 AM   #2
Rewards Points: 14,306
And what happens when you tighten up that stem nut after the waters turned on?
I'd guess there's some mineral build up on the shaft of the stem.
To fit it you would shut off the water at the main relieve the pressure in the line, remove the handle, remove the packing nut and clean up the shaft.
Still not working right, just replace the valve.
Old 01-07-2013, 09:00 AM   #3
Roofmaster
Rewards Points: 2,210
Nice neat holes through the wall. Dont they have these where you live?
Old 01-07-2013, 02:35 PM   #4
Rewards Points: 744
Those weren't too common in older construction.
Seattle2k is offline   Reply With Quote
washing machine hoses are leaking. tahmey@sbcgloba Plumbing 4 06-29-2011 07:51 PM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 05:10 PM
Dripping washing machine connection icespide Plumbing 4 11-11-2010 08:41 PM
Washing Machine compression valve leaking...HELP! tmcguirk Plumbing 12 04-17-2008 08:16 AM
