Washing Machine Hoses Are Leaking. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2011, 03:58 PM   #1
washing machine hoses are leaking.
after hooking hot and cold hoses tothe faucet should the faucets be turned on for both?
tahmey@sbcgloba is offline   Reply With Quote
Old 06-27-2011, 04:01 PM   #2
water leaking from hoses
after installing a washing machine water is leaking from around the hoses at the faucet connection.should faucets be turned on/
Old 06-27-2011, 04:11 PM   #3
X-Runner's Avatar
Are there gaskets in the hose connections? The little black rubber rings in the ends is what i am talking about.
X-Runner is offline   Reply With Quote
The Following User Says Thank You to X-Runner For This Useful Post:
oh'mike (06-27-2011)
Old 06-27-2011, 05:10 PM   #4
DIY staff
Rewards Points: 7,174
Sounds like the hose washers are missing --take off the hose and look----
Old 06-29-2011, 07:51 PM   #5
The hot water hose was leaking at the connection to my daughter's washing machine. I thought it was the washer, but it still leaked after I installed a new one. I bought a new set of hoses and the leak stopped.
David
Jessidog is offline   Reply With Quote
FloodSafe Washing Machine Hoses IdahoBob Plumbing 13 10-29-2011 04:23 PM
Leaking washing machine amyevans General DIY Discussions 9 05-26-2011 08:19 AM
Washing machine leaking sreed73 Plumbing 1 05-17-2011 06:51 PM
Flood safe washing machine hoses ielliott Plumbing 4 12-25-2009 12:56 AM
washing machine supply valve leaking tina2435 Plumbing 9 01-24-2009 04:17 PM
