Washing Machine Hookup Box - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2016, 03:53 PM   #1
Rewards Points: 877
I have the box in the photo that I want to connect to 1/2 CPVC water lines. The valve connections are machined inside to solder to copper. I want to use the outside threads and use a Metal/CPVC female adapter but not sure if these threads will work. Are they 1/2 inch pipe threads. The CPVC female adapter in
Photo seems to go on OK but I want to use one of those that has a factory Metal to CPVC connection and screws on like the plain CPVC female in photo.
JM
ddsrph is offline   Reply With Quote
Old 01-08-2016, 03:58 PM   #2
Rewards Points: 76
I'd solder a female adapter then use a male CPVC adapter. Screwing brass into plastic is asking for trouble. Plastic into brass is less likely to fail.
2x_Tom is offline   Reply With Quote
The Following 2 Users Say Thank You to 2x_Tom For This Useful Post:
ddsrph (01-08-2016), Yodaman (01-08-2016)
Old 01-08-2016, 04:14 PM   #3
Rewards Points: 877
Tom
Thanks. I was hoping to avoid soldering but like you said I don't like the brass into the plastic female adapter. I guess my main question is what kind of threads are those? If compatable with female 1/2 inch pipe, Lowes sells a metal female factory fused to a female CPVC.
JM
Old 01-08-2016, 04:39 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,.... I believe the threads are straight 1/2" pipe, rather than tapered pipe,....
It'd take an o-ring/ gasket type fittin', rather than pipe dope,....
The Following User Says Thank You to Bondo For This Useful Post:
ddsrph (01-08-2016)
Old 01-08-2016, 04:46 PM   #5
Rewards Points: 76
Most of the ones I've seen are running threads, not IPS. I've seen people jam copper female adaptors on there and get them to seal. I wouldn't try it though. If you really really don't want to solder they make those boxes with PEX outlets. Get one and use a pex female adapter and a CPVC male adapter to convert over. You'd have to invest in a pex crimper though. I'd suggest just finding someone to make the sweat connections for you or getting what you need to do it and learning how.
Old 01-08-2016, 05:12 PM   #6
Rewards Points: 877
That would be the safest thing to do. I can easily find someone to solder for me. I can gas weld and would feel confident to do it if I had the stuff needed but for two joints I will just get someone to do it for me.
Old 01-08-2016, 06:56 PM   #7
Rewards Points: 2,106
http://www.lowes.com/pd_339842-138-3...uctId=50070383
CPVC outlet box
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
ddsrph (01-08-2016)
Washing machine question Underestimater Electrical 3 03-05-2015 09:46 AM
Add washing machine hookup away from plumbing riser in high-rise apartment neoteric5 Plumbing 1 09-24-2012 10:35 PM
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 12:07 PM
washing machine hookup problem poppito Plumbing 5 03-11-2010 02:17 PM
