Washing Machine Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2009, 10:15 PM   #1
Rewards Points: 1,088
It seems kind of tricky to remove/replace one of these if necessary.
Tricky in that if you have a washing machine in a finished area, your faucets are likely located in a plastic box inside drywall.
So, if you ever have to replace a faucet, you have almost zero access to the pipe that the faucet is secured to, so when you try to twist the faucet off, that means the pipe inside is twisting also and it's possible to break a weld because you can't secure the pipe down when trying to remove the faucet.
If there is ever a leak in the valve stem/packing nut of a faucet, and tightening down on this nut doesn't eliminate the problem, you are better off replacing the seal under the packing nut instead of trying to twist the entire faucet off.
I was at HD today and disassembled a faucet and noticed that the "packing" is just a cone shaped seal. That's contrary to what I've read on this blog not long ago that "packing" was some sort of thing you wrap around the stem.
HD had many sizes of cone shaped seals, so it seems like if you ever have a leak in the packing nut/valve stem, just do the following:
1. Shut the valve off.
2. Remove the handle.
3. Remove the packing nut.
4. Check the seal for an ID#.
5. Go to HD and buy the replacement packing nut seal. I saw a 5 pack selling for roughly around $1.50 while an entire faucet would cost like $7.
Thoughts?
handy man88 is offline   Reply With Quote
Old 02-26-2009, 11:18 PM   #2
Wethead's Avatar
Yes, That is a fine way to save money and also do it yourself.
"Packing" is what they used to use back in the day, now in more recent times you will see "seals"
and yes, that is a great way to fix the valve.
Need Help With Your Pump?►WeT HeaD Pump Repair ► Watch Me On YouTube: Pump Repair TV
Wethead is offline   Reply With Quote
Old 02-28-2009, 05:35 PM   #3
Thanks for confirming this.
Old 03-21-2009, 11:53 PM   #4
Wethead's Avatar
No problem, glad to be of help!
Old 03-23-2009, 10:41 AM   #5
Rewards Points: 1,418
Whenever possible, replace the stem packing if needed before trying to replace the faucet.
Occasionally a "seal" is too big to fit so the the packing nut won't go on far enough to catch back on the threads. Here you have to buy old fashioned packing string as picture above.
Washing machine faucets should be turned off each time you are finished using the machine. Unfortunately this means the faucets may need service more often thay you may expect. For this you can not tighten them so much and thus prolong the life of the faucet washers. Floods from burst washing machine hoses rank high in the categories of claims insurance companies deal most with.
Old 03-23-2009, 02:25 PM   #6
These are two totally different items for two totally different uses.
A faucet (or bibb) washer is designed to go on the end of the stem
where it bottoms out against the seat.
As AlanJ said, it's too big to be used as stem packing.
porchmonkey is offline   Reply With Quote
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 08:16 AM
Washing machine faucet cabinview Plumbing 4 04-26-2009 07:59 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 06:18 AM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
