Washing Machine Dripping At Hose Connector..HELP! - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2008, 05:38 PM   #16
Originally Posted by handy man88 View Post
Check also the condition of the male connectors on the valves to make sure they are not scored on the surfaces where the seals compress against.
This may be a loaded question, but what do the "male connectors" look like?
kswoot is offline   Reply With Quote
Old 10-24-2008, 05:52 PM   #17
Rewards Points: 1,088
When you screw two valves together, the male connector goes into the female connector (no pun intended).
The male connector is the one with the external threads; the female connector is the one with the internal threads.
For example, your hoses have both female threads, and the valves that they connect to, the supply faucet in the wall, and the connection on the washer, are male.
handy man88 is offline   Reply With Quote
Old 10-24-2008, 07:09 PM   #18
Wow, you've got to be kidding me! I'm SO glad I didn't ask a plumber or some guy at Home Depot that question!
Anyway, the threads shouldn't be scored after just 3 mos.
I'm going to switch the hoses back and see what happens. If it leaks again I'm going to give up and buy a new CW hose.
Either way, before the connectors have their torrid affair, should I put this
stuff called Tplus2 on them? It says it "seals and lubricates threaded connections on metal and plastic pipe". Would this keep them from future
scoring?
thanks
Old 10-24-2008, 07:40 PM   #19
scoring?
thanks
"Lube" for the threading and the screwing (a little bit of pun intended) is supposed to be good, but some lubes are not meant for some type of plastic connectors. For example, some lubes can't be used for PVC connectors because it will eat away the plastic because they are harsh.
Also, this lube can make screwing so easy that you can easily strip the threads.
Instead of lube, you may want to consider some "protection" such as Teflon tape wrapped about 3 times around the male threads before screwing.
Hope you didn't faint.
Old 10-24-2008, 09:12 PM   #20
[quote=handy man88;176457
Hope you didn't faint.[/quote]
Not a chance! Thanks for your colorful tips! I still haven't switched the
hoses back. I've decided to enjoy my evening and deal with it in the a.m.
Stay tuned......
Washing machine lint filter Dragonladie Plumbing 4 10-19-2008 07:52 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
Ductless unit has dripping hose in basement tockfull HVAC 3 07-20-2007 09:17 AM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 08:24 PM
