Washing Machine Dripping At Hose Connector..HELP! - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-20-2008, 02:08 PM   #1
Washing Machine Dripping at Hose Connector..HELP!
Hello. My 3 mo. old washer has just started dripping water. It appears to be coming from where the cold water hose connects to the washer.
I shut off the water and unscrewed the hose. (that just seemed like the thing to do!) Now what? I see a tiny screen and a washer, but how do you get these out to check them? The connector spins and spins, but never comes off. The washer and screen look fine and are only 3mos. old.
Any ideas would be appreciated. Of course I just discovered this as my husband was walking out the door for 4 days. He says "go buy a new hose", without even looking at it! Is that what I need to do? Thanks...
kswoot is offline   Reply With Quote
Old 10-20-2008, 03:58 PM   #2
DIY'r
ScottR's Avatar
Did you replace the hoses when you got your new washer? If not, you should get new hot & cold hoses regardless of the problem, because these hoses fail with age. Make sure you get the braided style hoses. This is just an example; any home center or hardware store will sell similar hoses:
http://www.lowes.com/lowes/lkn?actio...24640-131-574L
If the hoses are new, then is the leak coming from the area where it screws onto the machine, or from the back of the connector?
If it's coming from the screw connection, you may just need a new washer (costs a few cents at any hardware store). If it's coming from the back of the connector, then you should get a new hose.
Of course, make sure the connection is snug (hand tight) before buying anything.
ScottR is offline   Reply With Quote
Old 10-20-2008, 04:42 PM   #3
Thanks ScottR. The hoses are new. It seems to be dripping from the
connector, but it is hard to tell. I'm going to turn the water back on to
sheck it our. How do you get the washer out of the connector?
Old 10-21-2008, 03:03 PM   #4
DIY'r
ScottR's Avatar
You can pry it out with a small flat head screwdriver or pocketknife..
If the hoses are new, though, first just make sure that the washer is seated all the way, and that it's flat, even, and undamaged.
Old 10-21-2008, 03:21 PM   #5
Rewards Points: 1,088
Using a pocket knife could actually cut the washer and render it useless.
What you may need to get is a pair of channel lock pliers, not only to remove the washer, if necessary, although unlikely, but you may also need to use the channel lock pliers to tighten the female connectors on the hoses onto the supply valves.
http://www.northerntool.com/images/p...s/15888_lg.jpg
handy man88 is offline   Reply With Quote
Old 10-21-2008, 03:24 PM   #6
DIY'r
ScottR's Avatar
Indeed.. though if replacing it, it's not an issue.
That's fine if the washing machine has metal threads. If the supply hookups are plastic, it's easy to over tighten and damage the threads.
Old 10-22-2008, 06:36 PM   #7
I Think I fixed it!!
After atleast 5x of taking off the hose and staring into it, then re-connecting it, screwing it tight with my hands, instead of a tool (ultra paranoid about stripping threads ) and it still leaking, I decided to give it one last shot before buying a new hose.
Thanks to Handy Man88 for including a picture of the channel lock pliers.
I went to the toolbox, grabbed the pliers and tightened away!
No more leak! I feel like such a stud! Not really. But seriously, I do feel a sense of accomplishment. Thanks to all you guys for your help.
BTW the connectors are plastic, so keep your fingers crossed that I didn't over tighten! I'm off to do laundry
Old 10-22-2008, 09:14 PM   #8
Rewards Points: 862
That's all it takes sometimes. The washer creates a lot of vibration, and can easily work the connection loose if it wasn't properly tightened.
Glad to hear that you have the problem fixed.
Ultrarunner2017 is offline   Reply With Quote
Old 10-22-2008, 10:12 PM   #9
DIY'r
ScottR's Avatar
Aw nerts, sorry I made you paranoid..
It just happens a lot that people get overzealous and think "just a little tighter and maybe the leak will stop.." and then they've got a bigger, more expensive problem. (Err, by "people" and "they", I mean it's happened to me ).
Anyway, glad you got it all cinched up!
Old 10-23-2008, 10:27 AM   #10
Which bears the question why a fitting that sees a lot of vibration would be plastic instead of metal.
Old 10-23-2008, 05:22 PM   #11
I spoke too soon!
Just came in from work and there is water all over the floor!
I hooked up the hot water hose to the cold connector, no leak.
So I thought, ok then it must be the CW hose itself that is bad.
But, my curiosity led me to hook the CW hose to the hot connector and guess what, NO LEAK! What the heck?
(Maybe it will be leaking later, so I'll check it in a few hours.)
I'm sure all this screwing and unscrewing I'm doing can't be good.
Should I give it over night to see if it leaks before switching them back?
Old 10-23-2008, 06:40 PM   #12
Man of many hats
wrangler's Avatar
Rewards Points: 354
Back up a minute... You say that you came home and water was all over the floor. When you proceeded to switch the hoses, was one of them leaking? If from your post, we can assume that the CW hose WAS leaking, from where was it leaking? From where the rubber of the hose is clamped to the screw on fitting, or where the fitting itself connects to the washing machine? If the hose was not leaking prior to switching them, could it be that something else is seeping water? I assume the washing machine was not running when you left?
Man of many hats
wrangler is offline   Reply With Quote
Old 10-24-2008, 10:24 AM   #13
No the machine has not been run since this all started. Yes, the CW hose was leaking. I couldn't tell if the water is dripping from the connector, or from the hose. If I shut the water off, and then turn it back on, I can hear a whoosh of air hiss for a second and then it starts to leak. There is no screw on the fitting.
BUT, I left the hoses in the switched status, with the water turned on all night, and there is no leaking. Doesn't make a bit of sense!
Old 10-24-2008, 03:35 PM   #14
If possible, you may want to take some pictures of your hoses and also of your valves on both the supply end and the washer end.
Hoses aren't that expensive, and if cheap ones were installed, then you should replace them. Also, I don't really see a benefit of having filters on the hose connectors.
Check also the condition of the male connectors on the valves to make sure they are not scored on the surfaces where the seals compress against.
Old 10-24-2008, 04:18 PM   #15
Rewards Points: 862
If it's a Kenmore, then it's most definitely plastic. They've been using plastic for more than 30 years. The only reason I can see is that it cuts mfr cost.
Washing machine lint filter Dragonladie Plumbing 4 10-19-2008 07:52 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
Ductless unit has dripping hose in basement tockfull HVAC 3 07-20-2007 09:17 AM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 08:24 PM
