Washing Machine Drains Causes Bubbling In Kitchen And Bathroom Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2012, 09:26 AM   #16
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,638
Pushing a lot of water out of the pump, compared to the previous. Heavy Duty would have nothing to do with the volume of water, it is how long they will last, compared to cheaper models.
I would fix the drain/waste line and see if that resolves the issue first, before doing anything else. Also, you did not answer about if you have trees in the yard, where the main waste exits the house, or to the septic if you have one.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following User Says Thank You to gregzoll For This Useful Post:
Bdterry (11-08-2012)
Old 11-08-2012, 05:51 PM   #17
hate to be a bug
i used some draino build up remover and the next day the bathroom didnt have the smell but the kitchen was backing up in sink then even where water comes out of washer started to overflow. grrrr, sucks to be poor let me tell ya. so im assuming it has to be blocked somewhere after sink drain. how would i go about looking at the drain waste? i looked under house and the pvc i think is the drain starts with a slope then bottoms out on ground for a few feet then looks like it raises a little bit... thanks for all the help keep it coming please.
Bdterry is offline   Reply With Quote
kitchen sink drains to sump pit csab_ Plumbing 5 01-08-2012 06:24 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
Kitchen sink backing up to downstairs bathroom! macon215 Plumbing 1 09-25-2010 06:41 PM
Using same tile for bathroom and kitchen too Matchy-Matchy? Jeanene Interior Decorating 10 03-29-2010 12:38 AM
