Washing Machine Draining Outside - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-12-2011, 08:50 AM   #1
Thumbs down
Hi guys,
I just bought a 5 year old investment property, so I've never really used the washing machine plumbing. My new tenant said that the washer is draining onto the lawn outside. I've never heard of this before. There is a pan that the washer sits on that I thought drained outside, but the tenant said that the main washer drain is going outside of a 2" drain straight out on the lawn. Maybe in warmer climates this is ok, but it gets darn cold here.
When I go to the house to look at it, what should I look for?
Thank you!
redcrawl is offline   Reply With Quote
Old 06-12-2011, 08:58 AM   #2
DIY staff
Rewards Points: 7,174
I've got a neighbor with a set up like that----It gets mighty cold here,too.
Look for a path to the drains---or consider a sump box with a pump and go overhead if your situation makes a gravity drain impractical.
Old 06-12-2011, 11:57 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Could be that was the original intention and the project ran out of money and/or it was forgotten about.
Journeyman Plumber
Old 06-12-2011, 02:03 PM   #4
So it may have been designed this way? I thought washer drains always drained to the home sewer system. The overflow drain for the washer pan should go outside maybe? Could a backup be causing it to go out the wrong drain? Thanks.
Old 06-12-2011, 04:56 PM   #5
DIY staff
It wasn't designed----it was a mistake--over site or or change of location.
That is a funky,make do set up---find a way to drain that properly and you will be much happier.
My neighbor closed in a porch and heated it (30 or 40 years ago--he's 90 something)
Then thought it would be nice to get the machines out of the house---he ran a temporary hose through the siding----decades ago.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 06:10 PM
Draining washing machine into cleanout mopar383 Plumbing 3 02-27-2011 06:55 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 09:02 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
