Washing Machine Drain Trap Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2011, 11:56 PM   #1
washing machine drain trap question
I just read that the trap for a washing machine is supposed to be "removable"
Is this correct, because mine is going in the wall... which I'm quite certain is common.
I thought it was against code to have a compression fitting within the wall.
Can someone tell me which is correct. I think I'd rather seal that puppy up and cut the whole thing out if I have a problem rather than finding out I have some kinda slow leak from the compression fitting in a year or two.
graysqwrl is offline   Reply With Quote
Old 09-10-2011, 12:56 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Compression joints and unions are to be readily accessible, not hidden in a wall
Old 09-11-2011, 01:05 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 812
Can you cite the source of this? I don't think I have ever seen a washing maching p-trap exposed? I've seen lots of washing machines dump into a sink...but not an exposed p-trap.
Old 09-11-2011, 03:26 PM   #4
it depends on your local plumbing code, normally they go by the international building codes, (www.iccsafe.org)
http://www.hawthornesplumbing.com
pdhawthorne is offline   Reply With Quote
Washing machine in basement drain pinkertonpv Plumbing 7 05-13-2010 08:58 PM
Washing machine drain line noise MikeKy55 Plumbing 2 12-03-2009 09:19 PM
Removing washing machine drain from septic 12172003A Plumbing 2 07-25-2009 06:32 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Washing machine drain --P-Trap ??? DVLCHLD Plumbing 2 09-14-2008 11:23 PM
