Washing Machine Drain Through Brick Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2013, 10:01 AM   #1
Rewards Points: 32
My parents are wanting to move the hotwater heater, washer and dryer to make room for some cabinets. Where they are now was the exterior wall with brick on the other side of the wall. They had a room built and now want to move everything to the other side of the wall. Should be an easy project to pull the paneling and run the lines through the brick. But was wondering about the washing machine drain. If I drill a 2" hole through the brick and install a 90 to the top of the drain pipe can I just run the rubber drain hose through the brick and into the 90?
rkersh409 is offline   Reply With Quote
Old 03-10-2013, 10:51 AM   #2
Roofmaster
Rewards Points: 2,210
You need to post some pictures.
Old 03-10-2013, 10:58 AM   #3
Rewards Points: 2,516
Was a room built onto the opposite side of the exterior wall that the washer/dryer is on?
hammerlane is offline   Reply With Quote
Old 03-10-2013, 11:14 AM   #4
Rewards Points: 32
Yes it covers the entire side of the house. The dryer vent has already been run and is 90 in the wall and running about 5 feet to the new exterior wall.
Old 03-10-2013, 11:22 AM   #5
Is there a standpipe or is the washer draining into a laundry tub?
Washing Machine Drain Through Brick Wall?-img00100-20100329-1637.jpg   Washing Machine Drain Through Brick Wall?-washer-20pic.jpg
Old 03-10-2013, 11:29 AM   #6
Rewards Points: 32
It has a standpipe inside the wall with the standard drain/valve box recessed into the wall.
Old 03-10-2013, 02:08 PM   #7
Roofmaster
The wall box that integrates the standpipe with the supplies makes a lot more sense to me. If the supplies leak the water goes down the standpipe, not in the wall.
Old 03-10-2013, 07:27 PM   #8
Rewards Points: 2,106
Short answer is no. What you need to do is open the wall and face the Washer box to the new room.
Old 03-10-2013, 08:20 PM   #9
Rewards Points: 32
Do they make one that is deep enough to go through brick, foam board and plywood?
Old 03-11-2013, 05:43 AM   #10
Who is the they you are referring to?
Old 03-11-2013, 07:51 PM   #11
Use 2- 45 degree fittings on the pipe above the trap to get it to the new box. Oatey makes a box that can be fastened to the brick with tap-cons.
Old 03-11-2013, 08:12 PM   #12
Rewards Points: 32
Thanks, you all have been a big help. Now the fun part, to drill through the brick.
How to vent washing machine drain line nateo Plumbing 1 12-31-2012 04:43 PM
Building a Washing Machine Drain Pan wiz561 General DIY Discussions 8 04-03-2011 02:51 PM
washing machine drain pan mark123 Plumbing 9 09-08-2010 06:50 PM
Washing Machine Drain Pipe tjeieio Plumbing 2 02-25-2010 05:19 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
