Washing Machine Drain Pipe Overflows - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2011, 06:10 PM   #1
Washing Machine Drain Pipe overflows
Washing Machine drain pipe overflows on every wash I do. It's been doing this in our home since we moved in 17 yrs ago. Our only solution was using some wire & hanging the washing machine drain hose an extra few inches higher than the drain pipe (which is setup at 2ft high behind the wall.) Now all of a sudden our little trick doesnt work anymore. Also there is a leak at the bottom of the pipe where it meets concrete(where the arrow indicates)
Why is this washing machine drain pipe doing this?
evol200 is offline   Reply With Quote
Old 01-27-2011, 08:10 AM   #2
The proper height for a washer drain pipe is 42", min 30" above trap.
Old 01-27-2011, 08:35 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Although your standpipe (vertical section) is a little short I do not think is the problem. I think you either have a partial clog in the trap or further down or a clogged vent. The piping looks like ABS so it is easy to work with. Since you have a leak anyways, I would cut out the trap and the sani-tee and replace it all. When you redo it, extend the standpipe section to the recommended height.
Coastal South Carolina
Old 01-27-2011, 01:41 PM   #4
Thank you for your replies. I needed some confirmation on the height. I did try to unclog the piping with a sink piping snake (which is '25 ft), nothing came up. So I was anxious to open the wall which was already deteriorated some to find out what it looked like behind there. Awesome, thanx guys.
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
Drain Pipe to Washing Machine houston81 Plumbing 10 07-07-2010 07:39 PM
Corrugated Washing Machine Pipe considiner Appliances 0 01-01-2010 05:14 PM
Washing machine drain line noise MikeKy55 Plumbing 2 12-03-2009 09:19 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
