Washing Machine Drain Overflow During Spin - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2013, 12:10 AM   #1
washing machine drain overflow during spin
what could the reason(s) be for my drain overflowing when the washer gets to rinseing the clothes?? Need some ideas to try. the washing machine is in the basement.
ToddMeek is offline   Reply With Quote
Old 02-25-2013, 12:14 AM   #2
Rewards Points: 13,270
Drains plugged up.
Old 02-25-2013, 08:31 AM   #3
Rewards Points: 1,442
Alternatively the washer drain standpipe is too skinny or is not built to code, or the drain system is not adequately vented (mouse or bird nest inside up above?). The current code calls for a drain standpipe and trap at least 2 inches in diameter. I'm not sure how much horizontal distance from the trap to the main drain is allowed.
The washing machine drain may be old enough to be grandfathered but some modern washing machines can pump out water faster than an older drain can handle.
AllanJ is online now   Reply With Quote
Old 02-25-2013, 08:58 AM   #4
Also the stand pipe needs to be at least 36" up off the floor.
I've often found lint blocking the traps a simple snake will clean it out.
washing machine drain aktasman Plumbing 1 11-14-2012 04:38 PM
washing machine drain pipe over flowing peskygnat Appliances 2 09-30-2012 07:56 PM
Unusual washing machine drain hose hook-up gnguru Plumbing 8 04-28-2011 09:40 PM
washing machine drain vent problems rebelbull Plumbing 7 03-29-2009 10:18 AM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 08:24 PM
