Old 12-01-2009, 11:57 PM   #1
MikeKy55's Avatar
Washing machine drain line noise
The house I own is about 7 years old. The laundryroom shares a wall with the master bedroom. The drain for the washer is in the wall between the laundry and bedroom. You can't start a load of wash and go to bed because when the washer pumps out the noise of the water going down that pipe (pvc) will wake you up. I have thought about adding a piece of rubber drain hose to the drain hose from the washer, long enough to reach the bottom of the vertical drain pipe. Thinking the water hitting that far down the pipe would be much more quiet. Opinions?
MikeKy55 is offline   Reply With Quote
Old 12-02-2009, 07:48 AM   #2
Drain pipe is porbably PVC, which is noted for being noisey. The only way I know of to improve that is replace it with cast iron, or open the wall and insulate the pipe.
Old 12-03-2009, 09:19 PM   #3
MikeKy55's Avatar
It is PVC
What are your feelings on using the spray foam we use for around pipes in exterior walls etc.? Drill a few holes the length of the wall and insert the nozzel?
water softener drain line moreira85 Plumbing 6 10-31-2009 01:14 PM
Drain height/Flood Level of washing machine wildbilly Plumbing 4 03-13-2009 09:09 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
