Washing Machine Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2012, 02:23 PM   #1
Rewards Points: 150
Washing machine drain
The house I just bought has the washing machine draining directly into the sump pump well. Is that a problem? The sump then drains out to the sewer anyway. The sewer line is at the basement ceiling so I am not sure how to have a washing machine drain upwards. I would appreciate any ideas. Thank you.
Cossack is offline   Reply With Quote
Old 05-27-2012, 06:40 PM   #2
Rewards Points: 1,500
The washing machine can drain to any place that its factory supplied drain hose can reach, although unfortunately a ceiling level drain pipe is too high. An official washing machine drain pipe (standpipe) is vertical and at least 2 inches in diameter and at least 18 inches long down to a trap which then taps into a drain
Draining into the sump pump well is not recommendted because the soapy water can deteriorate the sump pump and lint in that water could eventually clog the pump outlet pipe. You should have a sewage pump and well, usually a unit which sits on the basement floor, (which works the same way) instead.
Old 05-27-2012, 07:28 PM   #3
Rewards Points: 150
Allan thank you for the information. Can you tell me more about the sewage pump and well? Cost? Brands? Thank you.
Old 05-27-2012, 08:09 PM   #4
Rewards Points: 636
try one of these links
http://www.libertypumps.com/Products...?p=19&s=8&c=15
http://www.saniflo.com/project/index...pe/part/step/2
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-28-2012, 02:17 PM   #5
Rewards Points: 150
After many Google searches I have read that most modern washing machines can drain upwards of at least 96. My sewer line is about 6 off the basement floor.
Building a Washing Machine Drain Pan wiz561 General DIY Discussions 8 04-03-2011 02:51 PM
how do i get my LG front load washing machine to drain? heathrs Plumbing 2 10-15-2009 06:35 PM
Patching into existing drain with washing machine Kimball72 Plumbing 5 02-01-2009 04:28 PM
Washing Machine Drain mqcarpenter Plumbing 3 11-20-2008 07:47 PM
External Lint Filter for Washing Machine ? Piney Appliances 2 05-03-2007 11:28 AM
