Washing Machine Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2012, 12:44 PM   #1
Washing Machine drain
I am putting a washing machine in a storage room with electric and water supply but no drain. Can I run 2 inch pipe out of the room and into a french drain
franks58 is offline   Reply With Quote
Old 03-15-2012, 12:59 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Yes, as it is only gray water.
Make sure the drain pipe inlet is as high as the top of the wash machine or the washer will never fill with water.
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
franks58 (03-15-2012)
Old 03-15-2012, 02:00 PM   #3
French drain for washing machine
How big should i make the French drain?
Old 03-15-2012, 03:05 PM   #4
Civil Engineer
Rewards Points: 4,702
Titanoman, I believe you are incorrect on this one. In my town, where we are on septic, it is illegal to drain your washing machine or laundry sink, or any other graywater or blackwater source, onto the ground or into the groundwater. We don't know whether the OPS is on septic or town sewer, or has a private or public water supply. And we certainly do not know what the local regulations are. In this case, the only responsible way to approach this question is to ask your local board of health, or plumbing department, if it is permissible to drain laundry wastewater onto the surface or into groundwater.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
TheEplumber (03-15-2012)
Old 03-15-2012, 03:37 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 566
Totally illegal in my area.
Old 03-15-2012, 05:02 PM   #6
Rewards Points: 1,502
The detergent and lint laden water shortens the life of the sump pump.
AllanJ is online now   Reply With Quote
Old 03-15-2012, 07:03 PM   #7
Illegal here also.Big no no
plumberman134 is offline   Reply With Quote
Old 03-15-2012, 08:11 PM   #8
Disabled wood vet
titanoman's Avatar
Sorry to give bad info.
I'm in MO where you can pretty much do whatever you want.
Old 03-15-2012, 09:38 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 994
Florida Says no! fines up to 500 dollars a day if caught
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Building a Washing Machine Drain Pan wiz561 General DIY Discussions 8 04-03-2011 02:51 PM
how do i get my LG front load washing machine to drain? heathrs Plumbing 2 10-15-2009 06:35 PM
Patching into existing drain with washing machine Kimball72 Plumbing 5 02-01-2009 04:28 PM
Washing Machine Drain mqcarpenter Plumbing 3 11-20-2008 07:47 PM
External Lint Filter for Washing Machine ? Piney Appliances 2 05-03-2007 11:28 AM
