Washing Machine Compression Valve Leaking...HELP! - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2008, 08:53 AM   #1
Washing Machine compression valve leaking...HELP!
when i turn the hot water knob on our washer to turn water on to it, water shoots out the top. The cold water is fine and no leaks. I think it is the compression valve, but not sure...any suggestions to fix it? is it easy to replace? anyone have any tips?
Thanks alot!
tmcguirk is offline   Reply With Quote
Old 04-16-2008, 08:56 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Tighten up the packing nut seen just below the handle, that should fix it.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-16-2008, 08:57 AM   #3
I have already tried that....do you think it is just a matter of replacing the nut or does the whole thing need to be replaced? is it difficult to do?
Old 04-16-2008, 09:00 AM   #4
Journeyman Plumber
A picture would be nice, can you post one.
Old 04-16-2008, 09:01 AM   #5
I will definately do that when i get home....if you could take a look and let me know that would be great!!!!
Thanks Ron!
Old 04-16-2008, 07:30 PM   #6
Here are some pics...it is the one to the left.
If someone could help out that would be great!
Old 04-16-2008, 08:21 PM   #7
Journeyman Plumber
If it compresses onto copper, just get one just like it, turn water off remove the old one and by using the nut that is there, compress the new one on, all set ready to go.
Old 04-16-2008, 08:33 PM   #8
when you say compress, i am assuming that you just mean to tighten it down...?
Old 04-16-2008, 08:36 PM   #9
Journeyman Plumber
Yes, it does attach to copper right?
Old 04-16-2008, 09:04 PM   #10
yes it is...i believe it is sweated...
that is the correct term right??
Old 04-16-2008, 09:06 PM   #11
Journeyman Plumber
Does it screw onto a fitting? I can't see for sure in the pictures.
Old 04-17-2008, 08:08 AM   #12
Yes. it is screwed into a nut and right below that the wall begins and i cant see anything under that...what is the pipe that is under there falls behind the wall? I just want to make sure I do this correctly or else im in a world of hurt...
Old 04-17-2008, 08:16 AM   #13
Journeyman Plumber
See if you can unscrew it, hold the faucet with back pressure and turn the nut to your left, see if it will loosen up. If it does your ready to replace. Worst case you open wall to fix this.
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 12:26 PM
leaking stop valve farrington135 Plumbing 1 03-31-2007 06:33 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 08:23 PM
