Washing Machine Backs Up When Draining - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2011, 01:47 PM   #1
Washing machine backs up when draining
I have just installed a new front load washing machine, and when it is on rinse, it backs up out of the discharge hose....I feel as if the water is not able to get away quick enough.....it is all new 1.5" pipeing. I do not have the pipeing vented....could this be my problem ? And if so, I cannot vent to the outside....can I just vent into the laundry room ? Any venting would be after the trap.
Ric k
barrsy is offline   Reply With Quote
Old 11-28-2011, 02:38 PM   #2
Rewards Points: 582
its kinda hard to say with out seeing....but if its not vented that sure could be your problem..as far as venting in l.r DON'T...can you get me some pictures...
Old 11-28-2011, 04:36 PM   #3
Ben...I will take some pics of the connections from the washer to the drain pipe. This is all hooked into a sink that has a trap before the washer discharge pipe. The reason I can't vent to the outside is there is an apt. directly above the laundry room....venting to the outside is virtually impossible. Thanks
barrsy
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Washing Machine Draining Outside redcrawl Plumbing 4 06-12-2011 03:56 PM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 05:10 PM
Draining washing machine into cleanout mopar383 Plumbing 3 02-27-2011 05:55 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
