Washing Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2011, 10:25 PM   #1
washing machine
During spin cycle after rinse the washer drain overflows in the drain pipe when draining.
oscar62 is offline   Reply With Quote
Old 05-23-2011, 09:59 AM   #2
Rewards Points: 1,418
Did this same machine always do this?
The washing machine drain must be at least 2 inches in diameter and rise at least 18 inches above where its trap ties into the main drain. Higher if the rim of the washing machine tub is higher.
The washing machine hose must fit loosely into the drain opening.
Lint from a washing machine can eventually clog the drain.
The Following User Says Thank You to AllanJ For This Useful Post:
plumberinlaw (05-23-2011)
Old 05-26-2011, 11:39 AM   #3
Hi, 200.00 dollars later it was a clogged drain. That hurts....
They snaked it about 25 to 30 feet
I didn't have anything that long
But my wife will be happy.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 06:10 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 09:02 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
