Washer Stuck In Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2011, 11:41 PM   #1
Question
Washer stuck in fitting
I need to replace a washer to a valve stem in bathtub. No water comes out when the faucet is turned on. When I removed the valve stem I discovered that the bottom screw (used to hold the washer on) and the washer had come off the valve stem and are stuck in the fitting.
Any ideas how to remove them? I tried a screwdriver.
tedmpaul is offline   Reply With Quote
Old 08-02-2011, 06:34 AM   #2
Pair of needle nose plier, cut up the washer with a utility knife(don't nick the seat), turn on the water...........all or either should work.
Old 08-02-2011, 11:15 AM   #3
Rewards Points: 3,130
There is actually a tool for this. It's called a gasket pick. But Just Bill's suggestion should work.
Old 08-02-2011, 06:37 PM   #4
Household Handyman
Rewards Points: 1,408
I have actually done this with a piece of clothes hanger wire. Use a pair of pliers to bend a short hook on the end of the wire, file or somehow make a sharp point on the end of the hook. Insert the wire into the cavity where the stem goes, try hooking the sharp point into the old washer to pull it out. OR- try to hook the end at the outer edge of the washer if you have room for this. Another way is to use the coat hanger wire without the hook. Again file a sharp point on the end, try to pierce the old washer for removal. If successful--pay yourself on the back.
Old 08-08-2011, 02:53 PM   #5
Thank you
Thanks for all the ideas. I ended up removing the valve stem leaving the stuck washer behind. I then turned the water on and the water pressure blew the washer out. I had someone stationed at the water shut off valve so not that big a mess to clean up.
I first tried a gasket pick but washer was really stuck in the fitting.
Old 08-08-2011, 03:27 PM   #6
if all else fails you can get a seat wrench and remove the seat then the hole should be large enough for the washer and screw to be flushed out.
Tags
valve stem , washer stuck in fitting
stuck compression fitting on copper pipe John Malarkey Plumbing 2 05-10-2011 08:23 PM
Maytag washer stuck on hot KaiGywer Appliances 1 04-24-2011 07:35 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
Stuck fitting -- any expert tips? RDS Plumbing 6 03-04-2008 07:38 AM
