Washer & Sink Hookup... - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2012, 05:56 PM   #1
Rewards Points: 30
washer & sink hookup...
Ok so here is the story, the wife wanted a sink next to the washer.
So i did a rough-in and she ran the washer and once i got a little water backup (about 1 cup) into the sink drain.
Is this done correctly or what would you guys change?
I know it should be a 2'' abs tube but its a 1 1/2'' and everything was fine till i added sink.
I am thinking its because the drain for the sink is below the washer , but the reason i did it that way is cause if not the drain would be too high (18'' +) for the sink.
Any ideas ?
BTW where you see the orange wire it leads to a AAV and main drain is coming from the right side.
Thanks in advance !!
phantomvs is offline   Reply With Quote
Old 09-10-2012, 07:09 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 568
You guessed correctly. The sink needs to be above washer or given your layout, downstream on the horizontal
Old 09-11-2012, 11:17 AM   #3
Rewards Points: 30
thanks , thats what i was thinking.
My main problem is height, putting the sink above will be too high !
Old 09-11-2012, 11:20 AM   #4
and it should be 2 inch pipe for a washing machine. the larger capacity washing machines will pump an 1-1/2 pipe full when they drain.
Plumb Washer & Laundry Sink Into Existing Stack hammerlane Plumbing 12 10-26-2011 06:42 AM
bathroom sink hookup joetab24 Plumbing 8 09-06-2010 08:24 AM
Water and drain hookup problems with washer and septic system. Snav Appliances 4 01-27-2010 11:01 AM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 06:42 PM
