-   -   washer & sink hookup... (http://www.diychatroom.com/f7/washer-sink-hookup-156437/)
phantomvs 09-10-2012 05:56 PM
2 Attachment(s)
Ok so here is the story, the wife wanted a sink next to the washer.
So i did a rough-in and she ran the washer and once i got a little water backup (about 1 cup) into the sink drain.
Is this done correctly or what would you guys change?
I know it should be a 2'' abs tube but its a 1 1/2'' and everything was fine till i added sink.
I am thinking its because the drain for the sink is below the washer , but the reason i did it that way is cause if not the drain would be too high (18'' +) for the sink.
Any ideas ?
BTW where you see the orange wire it leads to a AAV and main drain is coming from the right side.
Thanks in advance !!
TheEplumber 09-10-2012 07:09 PM
199 Attachment(s)
You guessed correctly. The sink needs to be above washer or given your layout, downstream on the horizontal
phantomvs 09-11-2012 11:17 AM
thanks , thats what i was thinking.
My main problem is height, putting the sink above will be too high !
DannyT 09-11-2012 11:20 AM
and it should be 2 inch pipe for a washing machine. the larger capacity washing machines will pump an 1-1/2 pipe full when they drain.
