Washer Retainer Won't Tighten - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2012, 10:49 AM   #1
Washer retainer won't tighten
I removed my Price Pfister valve stem assembly to replace it due to leaking. When I started the re-build, the washer retainer screwed in , but would not tighten. It just kept turning. I tried to remove it to see what the problem could be and again it just turned. I can't remove it nor tighten it. I did try to leave it and continue to reinstall the faucet, but now it has a slow drip. Is there a way to get the washer retainer out and repair the problem without taking out the tile and making this a bigger project then I started with?
Poulos6 is offline   Reply With Quote
Old 02-17-2012, 10:58 AM   #2
Rewards Points: 14,026
A picture will help.
Shower, kitchen sink, vanity faucet?
Old 02-17-2012, 11:03 AM   #3
Sorry, it's in the shower and it's put back together at this point so picture won't help. I can take it apart and get pictures if that helps. I did this late last night, today's a new day
Old 02-17-2012, 02:08 PM   #4
Rewards Points: 352
I think the threads on the stem are worn out.Try disassembling again. When you try to remove the stem pull on it while turning to see if the threads will catch.
plumberinlaw is offline   Reply With Quote
Old 02-17-2012, 02:47 PM   #5
It's actually not part of the stem assembly. It's the faucet valve seat that is spinning freely. . I am using a seat removing tool to to try and remove it. Can't get a grip on it with this to pull back
Draining laundry sink into washer stack? glamgirrl Plumbing 33 12-31-2011 02:02 PM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 02:41 AM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
