Old 09-04-2012, 01:43 PM   #1
Maryland
Washer Outlet Box Valves
I hope that someone can explain this to me. Why is it that every washer outlet box I've come across, the valves have straight threads for connecting to the supply system? It's always been my understanding that straight threads are for joining and pipe threads are for joining and sealing. If I plumb with say.. CPVC, I would need to connect a transition adapter to the washer valve. The valve has straight threads and the adapter has pipe threads, so the valve would only screw about 2 threads into the adapter. This would almost certainly leak, right? What am I missing here?
Pittsville is offline   Reply With Quote
Old 09-04-2012, 03:26 PM   #2
call me E
TheEplumber's Avatar
The machine threads are for tightening the valve to the box only. More then likely, you're looking at valves made for copper- the pipe sweats inside the valve body.
If you want to use CPVC, you need a box w/valves specif to CPVC. Same goes for PEX
Old 09-04-2012, 03:33 PM   #3
Maryland
Makes sense. Thanks for clearing that up!
power outlet vs. water supply position for washer amakarevic Electrical 2 10-22-2011 08:00 AM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 05:20 PM
washer/dryer frying my outlet dontwannadiy Electrical 15 07-28-2009 12:52 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 03:44 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
