Washer Leaking During Spin Cycle - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2010, 11:40 PM   #1
jackofall,master of some!
Unhappy
washer leaking during spin cycle
My washer is leaking during the spin cycle,where should I start? is it a seal on the bottom somewhere, or is it by my drain tube?...?.?.? thx Ax
Axle Foley is offline   Reply With Quote
Old 11-04-2010, 06:25 AM   #2
if it is leaking near the door check the seal, if it is leaking slightly when spinning check the flexible hose which may have a small split in it.If it leaking alot then it may be best to remove the back and have a good look when the machine is spinning see if you can see anything.
Bobby_B is offline   Reply With Quote
The Following User Says Thank You to Bobby_B For This Useful Post:
Axle Foley (11-07-2010)
Tags
leaky washer , washer and dryer
GE Washer vibrates like crazy in Spin Cycle medicpg Appliances 12 04-19-2010 12:36 PM
GE washer No spin when loaded SPSNEXPERT Appliances 4 06-29-2009 01:39 AM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 05:03 PM
GE Washer Howls During Spin Cycle kennelm Appliances 1 02-10-2008 03:38 PM
washer spin cycle seems wrong markm Appliances 5 01-04-2008 02:10 PM
