-   -   washer leaking during spin cycle (http://www.diychatroom.com/f7/washer-leaking-during-spin-cycle-85735/)
Axle Foley 11-03-2010 11:40 PM
My washer is leaking during the spin cycle,where should I start? :huh: is it a seal on the bottom somewhere, or is it by my drain tube?...?.?.? thx Ax
Bobby_B 11-04-2010 06:25 AM
if it is leaking near the door check the seal, if it is leaking slightly when spinning check the flexible hose which may have a small split in it.If it leaking alot then it may be best to remove the back and have a good look when the machine is spinning see if you can see anything.
