Washer Hose Valves On Pipes??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2008, 07:45 AM   #1
washer hose valves on pipes???
am trying to take out old washing machine, but am unable to turn of stop valves on water pipes as they appear to be in a fixed position with a small screw in top- how do i turn them of? do i have to turn water of at stop cock and will this affect my combi boiler?
caron is offline   Reply With Quote
Old 04-19-2008, 09:56 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Washer shutoff valves typically get corroded and won't budge years later when you try to turn them. Althought the handles held on by the screw may crumble, you can try gripping them with channel-locks or a pipe wrench to turn thenm clockwise to close them.
If that doesn't shut off the water, you may just have to turn off your main.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 08:24 PM
