Washer/Dryer Relocation - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2009, 09:03 PM   #1
I have a 1960's 1 story ranch(no basement) and currentlly have the washer/dryer in the same area as my kitchen. My garage has electircal hookup for a dryer and all I would need to do is make a fix for venting, which wouldn't be a problem. Running a water line out to the garage is not a problem and relatively inexpensive. Question is, how would I drain the water since it's about 20-30 feet from the orginal placement and main drain line. Does the water need to drain through the main drain line or are there any alternatives?
Tim from Cincinnati
osty1969 is offline   Reply With Quote
Old 04-19-2009, 06:56 AM   #2
Gray water pump that pumps to a sewer line. I am assuming the you don't get a lot of freezing temps??? Pipes don't like that too much.
Old 04-19-2009, 09:58 AM   #3
Rewards Points: 150
First thing is are you going to have heat in the garage. do you have other drains close to the new location? Do you have a floor drain in the garage(this one might invovle breaking up concrete) Posting a pic might help. If you answer some of these questions we will try and figure something out. Finally you say its a one story ranch is it on crawl space or concrete slab.
al's sewer is offline   Reply With Quote
Washer/Dryer Hookup in Basement wombosi Plumbing 1 11-03-2008 09:41 AM
How to handle circuit for washer/dryer relocation? KUIPORNG Electrical 9 06-16-2006 09:09 AM
relocate washer/dryer krtw Remodeling 2 01-15-2006 02:39 AM
