Old 01-21-2010, 03:43 PM   #1
Washer Drains..... Soap comes out of floor Drain??
I have a house that was built in the 70's so I am not sure if anything has been changed plumbing wise since then, but when the washer goes into its drain cycle soap suds come out of the floor drain. I have put in a anti back up valve for the floor drain from home depot, but the suds do not float the valve. I am wanting to tile the area, in the future so I want to know what I can do to stop this from happening, hope fully it does not involve a jack hammer.
Thanks Cody
choda_boy_04 is offline   Reply With Quote
Old 01-21-2010, 05:44 PM   #2
This is a sure sign the drain is clogged somewhere. You can try to have it Roto Rootered but if that doesn't work you might want to hire a plumber with a drain video camera.
If tree or shrub roots have gotten into the drain pipes, you might succeed in get them cleared out but you will have to redo the chemical treatment at least twice a year to keep new root growth from taking over again.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 01-21-2010, 08:20 PM   #3
Are you using HE laundry detergent? If so, check how much you are putting in. The fill line on the cap is much lower compared to regular liquid detergent.
handy man88 is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General Discussion 3 08-23-2009 06:29 PM
white stains improvements Appliances 1 02-20-2009 05:26 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 07:41 AM
