Washer Draining? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-17-2012, 11:04 PM   #1
Washer draining?
I just hooked up my washer to drain into my sump pump. When the pump turns on i get a gargle sound coming from my bathroom. The bathroom is on the first floor right next to my bedroom. Is there anything i can do to prevent this sound?
Mallard1123 is offline   Reply With Quote
Old 10-17-2012, 11:08 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 676
Sewage pump or sump pump. there is a difference. Sumps should not receive gray water. Check your venting system
Old 10-17-2012, 11:10 PM   #3
Its a sump that goes up six feet and into the city sewer. If i cant drain in sump what do i do?
Old 10-18-2012, 07:30 AM   #4
Rewards Points: 3,130
Is this a new washer installation? If not, where did it drain before? Washers don't actually drain; the water is pumped out, so the discharge can be above the washer. I once had an older home where the sewer line ran along the basement wall, about 5 feet above the floor. There was an exposed trap and short standpipe for the washer to discharge into.
Laundry water shouldn't really go to a sump. It contains a lot of lint, as well as buttons, pocket change, etc. The pump will clog in no time.
Old 10-18-2012, 07:57 AM   #5
Yes its new for me i just bought the house. How can i tie into the sewer line its 3" copper. Also will the washer be able to pump it up 6-7 feet?
Old 10-18-2012, 08:52 AM   #6
Rewards Points: 352
do you have a utility sink or floor drain in the basement? What year was your house built?
plumberinlaw is offline   Reply With Quote
Old 10-18-2012, 09:00 AM   #7
1958 the utility sink is right next to it but it drains right into sump pump.
Old 10-18-2012, 09:58 AM   #8
Wow. Copper DWV lines. I once owned a house that had them as well. That stuff would cost a fortune today. As for your question, is the line 6-7 feet above the washer, or above the floor? If above the floor, you should be OK. But check the manual for your washer to see what it says about that.
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Draining laundry sink into washer stack? glamgirrl Plumbing 33 12-31-2011 02:02 PM
Washer draining causing sewage to backup into bathtub SuzyQ is Me Plumbing 5 08-19-2011 03:11 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
kitchen sink gargles when washer is draining Tonglebeak Plumbing 38 02-24-2010 12:43 AM
