-   -   Washer drain and sink in basement (http://www.diychatroom.com/f7/washer-drain-sink-basement-172661/)
rosem637 02-22-2013 11:54 AM
2 Attachment(s)
Want to setup the washer/dryer/laundry sink in my basement. Does the below setup look good to go?
TheEplumber 02-22-2013 12:47 PM
199 Attachment(s)
That looks nice. It will meet my UPC code requirements
A couple of comments- The lav can drain into the washer vent above the washer trap(wet venting). That will save a connection on your building drain. If you do that, the washer vent will need to be 2".
You don't have your lines sized- Washer drain= 2", Lav drain= 1.5" Current venting layout= 1.5" Again, I'm using UPC standards
What software did you draw with?
DannyT 02-22-2013 12:52 PM
looks good to me. you could run the sink drain off of the 2 inch going to the washer to save you a 3x1-1/2 wye.
what software are you using?
rosem637 02-22-2013 05:13 PM
1 Attachment(s)
Quick Plumb Pro
http://quickplumb.com/
rosem637 02-22-2013 06:17 PM
1 Attachment(s)
Get rid of the laundry tub and put in a toilet and lav sink. Use the lav drain as a wet vent for the toilet??
TheEplumber 02-22-2013 08:51 PM
199 Attachment(s)
That's fine. Keep the toilet vent 2" after the lav
