Washer Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2011, 03:34 PM   #1
Washer drain pipe
I need to know how to replace the drain pipe that is in the wall for my washer. The house was built in 1969 and the drain is too small to handle the large capacity washer. Could you please help?
hehowerton is offline   Reply With Quote
Old 04-25-2011, 05:34 PM   #2
yes, you could replace the pipe but before doing that, I'd give thought to the pipe being partially blocked, causing the water to back up. If you can, trace the pipe back to where it dumps into the main sewer, look for a clean out and take a look. built in 69' is a "newer" house.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 04-25-2011, 08:28 PM   #3
Rewards Points: 1,512
The drain pipe must be at least 2 inches in diameter and the open end must be at least 18 inches above the trap. If not then it likely that a modern washing machine will cause it to overflow.
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
Washer drain pipe and adding a utility sink lubyone1 Plumbing 5 07-09-2010 10:56 PM
Major drain issue... what is this pipe? moneymgmt Plumbing 9 08-04-2009 10:53 PM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
