-   -   Washer Drain Overflows (http://www.diychatroom.com/f7/washer-drain-overflows-137694/)
ryanb4614 03-20-2012 09:58 PM
Hello. Purchased our house in August 2011. It was built in 1953. Alot of caster iron. Everything I have been doing I have been switching over to PVC. The house came with an old washer and dryer. We finally were able to replace the washer and dryer. I hooked up the new washer yesterday of how they had the old one hooked up. It was going into a 1 1/2 pipe (cast iron). When the washer would drain it was overflowing. I figured the new washer has a more powerful drain. So I tore out the cast iron and put in PVC 2 inch. On this sewage line is the washer and kitchen sink. It is not vented. Kitchen sink drains great. By the way the washer is in the basement. So I hooked up all the 2 inch pipes and tested it and it still is overflowing out of the drain pipe. Any ideas? I hav to redo the plumbing anyways because I forgot to put a trap in the line! Its just one of those days. I am wondering if it is clogged? It sounds like its draining when listening near the pipes but then you can hear the water start coming up the pipe...
joecaption 03-20-2012 10:50 PM
Sure sounds pluged up to me.
plummen 03-20-2012 11:12 PM
Yeah id say the pump on new washer is too much for the old 1 1/2" drain line,maybe try having somebody cable it out to see if that buys you some time :)
