Washer Drain Lower Than Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2011, 01:35 AM   #1
Washer drain lower than floor
I am installing ceramic tile in my second floor laundry room. There is a PVC pipe that is the drain for the washer in the floor. After I lay the tile, the pipe will be slightly below the new flooring. Is this an issue and if so, how do I fix it? Thanks!
Vbradburn is offline   Reply With Quote
Old 03-07-2011, 06:26 AM   #2
hillbilly guru
Send a message via Yahoo to hvacguytn615
securing drain line so it wont come loose would have to be attched to the wall .just to be safe you may want to add a coupling and stubb up drain line. also check coeds may have a set hight depending on your area
hvacguytn615 is offline   Reply With Quote
Old 03-07-2011, 07:47 AM   #3
BIGRED
Rewards Points: 252
That floor drain is NOT for draining the washer. That is a requirement to protect your home from flood damage should there be any leaks or malfunctions with your washers water supply. If you have a 2" pvc pipe coming up through the floor (you should have) then you need to put in a 2" PVC shower drain to that pipe so that the top of the drain is the lowest point in the surface of your tile floor. The shower drain gets glued into the pipe and the tile gets mudded in right up next to the drain.
Grampa Bud is offline   Reply With Quote
Old 03-07-2011, 08:30 AM   #4
Rewards Points: 1,542
The washing machine drain must start with a vertical riser at least 18 inches long and 2 inches in diameter going into its own trap. The washing machine hose must fit loosely into this.
AllanJ is online now   Reply With Quote
Old 03-07-2011, 11:18 AM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
what allanJ said , if you use that pipe for your washer drain your washer will siphon all the water out of the tub and never stop filling
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-07-2011, 06:59 PM   #6
BIGRED
Rewards Points: 252
To Vbradburn: From all the comments and what you wrote in the first place I think we need to know if you are talking about a pipe coming up to your laundryroom floor or are you trying to drain your washing machine?? They are two different things handled in two very different ways.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
Floor joist lower than others drhowarddrfine Flooring 2 04-26-2006 03:25 PM
