Washer Drain Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2011, 08:10 PM   #1
Question
washer drain line
I'm moving my washer in the laundry room, but I have a question about drainage. We're on a septic system here, and the current washer drains into a french drain system and is carried 200 plus feet from the house out into a field. (Apparently, this is up to code in Alabama.) My question is...When I run my new drain line to be tied into the french drain system out back, do I have to install a p-trap before connecting the drain line to the french drain, or am I safe to let it just gravity drain since there's no gas coming back in?
jbarkley is offline   Reply With Quote
Old 05-07-2011, 08:16 PM   #2
the Musigician
DangerMouse's Avatar
I'd use the trap.... there may not be gas, but there could be smelly drain stink.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
jbarkley (05-07-2011)
Old 05-07-2011, 08:52 PM   #3
Homerepairguy's Avatar
Rewards Points: 998
To add to DangerMouse's reply, a trap not only stops smelly drain stink, but it also stops (or at least greatly minimizes) unwelcome live things from coming in.
HRG
Homerepairguy is offline   Reply With Quote
The Following User Says Thank You to Homerepairguy For This Useful Post:
Tags
drain , french drain , trap
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 11:11 AM
Washer Drain Pipe Install somewhatsketchy Plumbing 0 10-10-2010 11:13 AM
Water heater drain pan line Bigmike33 Plumbing 1 09-22-2010 08:29 PM
re-routing washer drain 71Whaler Plumbing 2 09-03-2009 11:30 AM
Clogged Drain line Ruski Remodeling 2 06-24-2009 06:29 AM
