Washer Drain Into Utility Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-20-2012, 07:37 PM   #1
Rewards Points: 49
washer drain into utility sink
Will the inspector have an issue with a washing machine draining into the utility sink? (hooked over hose) The drain line in the utility sink is 2".
I am also installing a "supply box" for the washer.
I am doing a bathroom/kitchen romedel, including changing from galvanized to copper water supply lines. I dont want to change any of the vent piping.
however a plumbing inspection is required, so i was hoping to have a heads up.
thx
john_bry is offline   Reply With Quote
Old 11-20-2012, 11:09 PM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
Do you know who you need to contact to get the inspection done? If so, I would just call and ask them about it before they come out.
fetzer85 is offline   Reply With Quote
Old 11-21-2012, 04:23 AM   #3
DIY staff
Rewards Points: 7,174
In new/updated plumbing the washing machine must have it's own drain---I don't know if that is a loal code or national--
Converting a Washer Drain into a Sink Drain - A Head-Scratcher TheJazzMan Plumbing 2 10-15-2012 07:09 AM
Relocating washer standpipe 71Whaler Plumbing 3 09-23-2011 10:23 AM
Washer drain pipe and adding a utility sink lubyone1 Plumbing 5 07-09-2010 10:56 PM
Maximum distance of sink from drain? DIYHomeTheater Plumbing 0 06-14-2010 07:42 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
