Washer Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2008, 02:03 AM   #1
Cool
washer drain
my washing machine is in a room that was added on to the house before I bought it. the problem is the drain line is in the original house with a hole cut thru the drywall for access. It also sets behind my range. I want it to be on the other side of the drywall behind the washing machine where it should be. I am buying a new range with a added cabinet and counter space. the drain needs moved first. The home sets on cinder blocks. so what is the easiest way to move the drain line. both rooms have tile floors. i have no problem cutting into the drywall behind the washer and dryer to place the drain only getting it over there.
ready4it is offline   Reply With Quote
Old 11-29-2008, 05:13 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 602
I think I'll move this to the correct forum
Last edited by slickshift; 11-29-2008 at 05:45 AM. Reason: granted chrisn magic powers for a moment
Washer drain fw2007 Plumbing 3 09-12-2008 02:02 PM
Washer tray drain plug proofer Appliances 5 08-24-2008 08:53 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
