Old 02-18-2013, 08:46 AM   #1
RustyRealtor's Avatar
Washer Drain
Hello,
I am trying to install a stackable washer/dryer in a tiny (475 s.f.) 2nd floor condo. I plan to put it in the bathroom, next to the vanity. The drain would have to run inside the wall and around the bend and over near the toilet. I can't run the drain under the floor. i have attached a floor plan (I think) and wonder if you kind folk can tell me if my plan is possible. I am afraid I will have too many bends in the drain.
Many Thanks,
Russell
RustyRealtor is offline   Reply With Quote
Old 02-18-2013, 10:31 AM   #2
call me E
TheEplumber's Avatar
Washer Drain
Do you know the pipe size at the lav area? You need 2" for a clothes washer
Old 02-18-2013, 10:50 AM   #3
Roofmaster
Washer Drain
Why not go through the ceiling and straight over to the soil stack behind the toilet in the attic? Not sure re the lift capability of a washer pump though. Others may be able to help here better.
" A lot of men build things, and a lot of things fall down "
Old 02-18-2013, 11:12 AM   #4
MarginallyQualified
Washer Drain
Originally Posted by RustyRealtor View Post
I am trying to install a stackable washer/dryer in a tiny (475 s.f.) 2nd floor condo. I plan to put it in the bathroom, next to the vanity...
Does this mean that the condo wasn't designed for or fitted with proper laundry equipment hook ups?
Old 02-18-2013, 04:26 PM   #5
Washer Drain
Thanks for the replies.
The condos were not originally fitted for washers. There is a small laundromat with three washers and three dryers, of which two are usually under repair.
The drain at the lavatory is 2".
I haven't considered going up and over - it might work, though. I'd rather not, if it can be avoided.
Thanks,
Russell
Old 02-18-2013, 04:40 PM   #6
Washer Drain
Are you sure the sink drain is 2-inch? That would be highly unusual.
Old 02-18-2013, 05:27 PM   #7
Master Plumber
Javiles's Avatar
Washer Drain
Forget going over the top unless you use a mini lift station. you'll need to be very careful where you tap into at this point from the drawing layout nothing would be legal, the second problem how severe would be determined by what material is the plumbing drain, Cast Iron or PVC , and venting, the down stairs unit would experience foaming, that would be every time the machine dumps water the down stairs unit would get suds in there fixtures tub toilet or sink, in one or all hard to say, if the plumbing system in the building was not designed for washer discharge you would be very lucky to be trouble free.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 02-18-2013, 06:35 PM   #8
Washer Drain
Hello again,
I am certain that the drain at the lav is 2".
And I guess I hadn't given much thought to the foaming in the down stairs unit. The drains are all PVC, by the way. The places were built in the mid seventies. I think i will hook up a drain and run a test load or two and see what happens down stairs - That unit is also mine. Whadda ya think?
Thanks,
Russell
Old 02-18-2013, 10:43 PM   #9
Master Plumber
Javiles's Avatar
Washer Drain
Hello again,
with out a pest for a neighbor you basically have a free ticket. get a plumber to pipe it in as close to code as he can get. all i can say.
Old 02-18-2013, 10:47 PM   #10
Master Plumber
Javiles's Avatar
Washer Drain
Hey E ,Down here he would need 3 inch for the washer branch. 2" will work just fine in my opinion. but it wouldn't pass inspection
Old 02-18-2013, 10:54 PM   #11
call me E
Washer Drain
We can still use 2" and suds relief doesn't apply either on residential work
I just hope he doesn't tie into a vent from the first floor....
Old 02-19-2013, 06:21 AM   #12
Washer Drain
Thanks a lot for all the advice. I will let ya know how it turns out.
Thanks,
Russell
Septic odor from washer machine drain TMC Plumbing 4 02-02-2012 08:40 PM
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 12:11 PM
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 11:46 PM
Water and drain hookup problems with washer and septic system. Snav Appliances 4 01-27-2010 12:01 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 11:35 PM
