Forums | Home Repair | Home Improvement | Painting | Interior Decorating | Remodeling | Landscaping
Old 01-28-2014, 04:09 PM   #1
Share |
Question
Washer discharge. Help!
Here's the story, trying to tie in a stand pipe and trap for a washing machine discharge line in my friends basement. The old plumbing is 3" steel and I can not get the clean out cap to budge. It's 1 3/8" hex head but someone rounded the corners and I can't get a wrench to bite. I've tried lube and hitting it with a torch, suggestions I found online. Any suggestions on how to get the plug out? Thanks in advance!!
Carpenter88 is offline   Reply With Quote
Old 01-28-2014, 04:39 PM   #2
Post a picture.
What type wrench you trying to use?
Old 01-28-2014, 05:03 PM   #3
It won't let me upload pic from my phone but it's a 3" clean out cap just like modern PVC however it has a hex head instead of the square head. I put a 1 3/8" hex head 3/4" drive with a 3 foot breaker bar but the head was already too rounded and the wrench just slips.
Old 01-28-2014, 05:05 PM   #4
Use a pipe wrench.
Old 01-28-2014, 05:13 PM   #5
MarginallyQualified
Originally Posted by joecaption View Post
Use a pipe wrench.
and some PB Blaster
and maybe a piece of pipe on the pipe wrench for more leverage.
Old 01-28-2014, 05:18 PM   #6
call me E
TheEplumber's Avatar
If it's brass, knock it out using a cold chisel and hammer. Of course, you'll need to replace it with a new one and don't drop the pieces down the pipe- I hope you're not tying the new pipe into there...... that's not an approved connection.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (01-28-2014), LateralConcepts (01-28-2014)
Old 01-28-2014, 06:02 PM   #7
Not to mention the venting aspect of plumbing....
Old 01-28-2014, 06:11 PM   #8
Owner
LateralConcepts's Avatar
So when your sewer backs up, it fills your washing machine with sewage?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 01-28-2014, 06:22 PM   #9
Owner
Sorry to be a little brash, but I run into this problem all the time. It not only eliminates the cleanout access for inspection or servicing; but as Eplumber also mentioned, that's not an approved method of tying in a washing machine drain.
Likewise; if it's an elevated cleanout and the washing machine can't gravity feed into the sewer, a pump basin needs to be installed. Otherwise you're just using the washing machine itself as a lift pump. Not what it was intended for. Like I mentioned in my first post, if the sewer ever backs up you'll have a nasty mess and will be buying a new washing machine.
Lateral
(208) 818-8241
Old 01-28-2014, 06:33 PM   #10
This is all good feedback. I was going to put a wye pipe in so I could still have access with the clean out. Someone above mentioned venting, the line goes up to the toilet so it should(and does) already have a vent through the roof. Any better suggestions from you guys on how to do this? Anybody ever figure out a really clever way to drain a washing machine? I have access to two clean outs, one from the toilet and one from the kitchen sink. The sink clean out is pinned back in a corner and I don't think I could attach the necessary equipment to it to make it work. Any ideas are greatly appreciated, and thank you all for the replies given already
Old 01-28-2014, 07:01 PM   #11
Owner
If you can post a picture of the area you describe, you'll get better answers. Does the main sewer exit through the foundation wall or is it under the slab?
Lateral
(208) 818-8241
Old 01-28-2014, 07:03 PM   #12
Owner
https://www.libertypumps.com/Data/In...0D_for_web.pdf
Lateral
(208) 818-8241
Old 01-28-2014, 08:13 PM   #13
This is a close up of what I'm describing.
Old 01-28-2014, 08:22 PM   #14
I'M GLAD YOUR TOILET IS VENTED NOW YOU NEED TO VENT THE WASHER.
Every fixture in a house has a vent.
What you have is a cast iron stack what you need to do is cut the cast iron stack after you support the pipe above it with friction clamps. That way the ton or so of cast iron doesn't rain on your parade. Then you need to insert a tee or y fitting with proper band adaptors. Run 2 inch to your washer with a vent prior to the trap of the washer. That vent will need to either tie into the vent 42 inches above your 1st floor toilet again cutting the pipe and supporting it. And only if it is a vent and no fixtures drain down it from upper floors at that point. Not easy but it is legal.
So what you need is a 4 inch cast iron friction clamp. A cast iron cutting blade or two for a sawsall and to be very careful. Also 4, 4 inch mission brand transitional couplings cast iron to plastic a 4 by 2 tee pvc a 2 by 1.5 inch tee pvc a 2 inch trap and a 4 by 1.5 inch tee for tying the vent back in above the toilet on the first floor. 2 inch pvc scd 40 pipe, 1.5 inch pvc scd 40 pipe, 4 inch pvc scd 40 pipe. You also may need a few 1.5 inch 90 fittings. All fittings have a DWV stamp. And PVC primer and PVC glue. No it's not a 30 min job and again did I say you may get hurt. I know plumbers that got careless and now have no thumb.
Old 01-28-2014, 08:44 PM   #15
Owner
Ok, that's good. Makes it easier. No need for a pump then. It appears you can gravity feed it. The licensed plumbers on this forum can help you with the proper way to tie it in.
Lateral
(208) 818-8241
Tags
clean out, clean out cap, discharge, washer, washing machine
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
bolt that holds the tank to the toilet bowl is leaking andrewjs18 Plumbing 13 04-06-2012 10:43 AM
Draining laundry sink into washer stack? glamgirrl Plumbing 33 12-31-2011 02:02 PM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 02:41 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
