Washer Backing Up Into Basement Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2010, 11:18 AM   #16
Rewards Points: 249
When you say mini-jetter, are you talking about the little bulb that goes on the end of the hose, shove it in, turn hose on? Is that safe for PVC?
Durt Ferguson is offline   Reply With Quote
Old 08-24-2010, 02:57 PM   #17
no you're talking about a drain king/water bag. don't use one unless you're very careful. If multiple fixtures are contributing to the blockage, and there are vent pipes that are backed up as well, water will not be forced against the blockage it'll be forced up your sink/tub/roof. This is a jetter http://www.ridgid.com/Tools/KJ3000-Water-Jetter call some local companies and ask about pricing for it
the_man is offline   Reply With Quote
Old 08-24-2010, 09:12 PM   #18
Owner
LateralConcepts's Avatar
Originally Posted by TheEplumber View Post
Durt, If your DW is draining ok and not backing up the basement shower I think your blockage is in the branch piping and not your mainline. You also said the basement FD is ok. Is that downstream from the shower? I think you need to use a mini jetter on the laundry/shower line. Or if you have a 3/8 cable, put a small bend in the first couple of inches. This will help scourer the pipe and grap lint/hair. If the pipe is sludged, if will act like a straw in a milkshake. Once you pull the cable out it will block again. A jetter will push the sludge away. Might get messy though.
I agree with TheEplumber. I'm curious however if you've recently changed brands of detergent or bought a new washing machine?
Some detergents foam/sud more than others and can block the top half of the pipe under the slab causing what you think is a blockage, but simply can't let air in.
If you've recently purchased a new washing machine, it may pump water out at a higher volume than your old one.
Maybe I missed it.. did you mention whether the laundry drain was 2"?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-26-2010, 08:21 AM   #19
Rewards Points: 249
Drain is 2", we have not changed detergents or gotten a new machine. Last night the upstairs bathtub was draining very slow, as well as the toilet. These are on a separate branch. I'm calling plumbers today to get prices.
Old 08-26-2010, 08:59 AM   #20
Owner
Sounds as though there's a blockage in the main somewhere if you have more than one drain acting slow, sluggish, or backing up. Trying to get pricing over the phone will be difficult because you don't know what the problem is, or you may have more than one problem. It will take a service technician to come out and diagnose the problem. Some may do that at no charge, others may charge you just to show up.
Lateral
(208) 818-8241
Old 08-26-2010, 09:21 AM   #21
Rewards Points: 249
So I am a first time homeowner for all of 2 months, and I have never called for this before. What kind of questions should I be asking them over the phone before picking one?
Old 08-26-2010, 09:41 AM   #22
Owner
Before calling them, I'd check with your neighbors, friends, family, bbb, etc. for recommendations. A large franchised company, i.e. Mr. Rooter, Roto-Rooter, etc. may provide amazing service in one town and horrible service in another. Pricing, warranties, can also vary. Depends on the management and quality of technicians. A small local ma 'n pa type shop may provide more reasonable pricing, but may not have the resources to get out to your place right away. Again, do some research.
When you do make the phone call. Just explain the situation without going into too much detail. Ask them if they have a charge to come out and diagnose the problem? Is it hourly or by the job? Are there fuel charges? Do they also do jetting/hydro scrubbing? Do they have cameras?
Lateral
(208) 818-8241
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Basement Shower Backup robbdc Plumbing 0 12-15-2009 08:22 AM
Washer Drain Backing Out with debris-HELP!!! CaliMom Plumbing 2 03-09-2009 05:36 PM
How to break the concrete for basement shower drain? epeterson777 Plumbing 2 01-18-2009 05:25 PM
shower in basement slab philip96 Plumbing 2 06-15-2008 09:46 PM
