Washer Backing Up Into Basement Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-23-2010, 09:55 AM   #1
Rewards Points: 249
Washer Backing up into basement shower
I'm having a problem where when the washing machine drains, the basement shower backs up and suds and water come up. Not a lot of water, maybe a 12" diameter puddle at the bottom of the shower. This never happened before about a week or two ago. I've done a little research on this, and would like some opinions.
Here are the specifics :
- The washer and utility sink are in the laundry room. On the opposite side of the wall, there is a bathroom.
- In the laundry room, I can seem the PVC drain line from the utility sink. The drain line from the bathroom sink comes through the wall and joins this line.
- The washer drain line meets the drain from the two sinks at a tee. This then goes into the wall. There is a cleanout plug at this tee.
- I assume that, inside that wall, the shower drain meets up with this line.
- We have not noticed any backing up, slow draining, or noises coming from any of the upstairs fixtures. To me this hints that the problem is before the washer/sink/shower line meets up with the main line.
- When washer drains, it backs up into shower. The sinks in the laundry room and bathroom make a gurgling/burping noise.
- I attempted to snake out the line via the cleanout plug in the laundry room. Didn't really find anything using a 25' snake.
- My next attempt is probably going to be to attempt to snake the line via the shower drain.
Any suggestions, tips, ideas? Or am I at the point where I should call a plumber? Do you suggest a local plumber or a roto rooter type place, and what does a call like this usually run, costwise? I want to get this taken care of before it turns into something worse.
Thanks!
Durt Ferguson is offline   Reply With Quote
Old 08-23-2010, 10:07 AM   #2
Wanted to mention one specific problem related to washing machine drains. The water from the washer contains lots of lint. Your snake can go right through the lint and then seal back up when you withdraw the snake.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-23-2010, 11:57 AM   #3
Rewards Points: 249
When I pulled the snake out of the cleanout plug it was pretty clean. Didn't really look like it'd run into much.
Old 08-23-2010, 12:27 PM   #4
fabrk8r
fabrk8r's Avatar
I'll ask the same question of you that I asked when someone else had a drain backup problem...is there a vent pipe close to the washer/shower drain?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-23-2010, 12:53 PM   #5
Rewards Points: 249
I can see the vent pipe on the roof and in the attic. It appears to be located near (within a 10 foot radius) of the location of the laundry room. However, it is hidden in the walls everywhere except the attic and roof. I went on the roof yesterday and used a flashlight to look into the vent and didn't see any obstructions.
Old 08-23-2010, 01:37 PM   #6
Durt, nothing on the snake is what I would expect if the clog (and you do have a clog) is lint. It is like going through oatmeal. I do not like chemical drain cleaners, but I do use Drain-care by Zep. It is an enzyme cleaner and clings to and eats organic matter. It will not work on tree roots, and does take longer to work than most methods. It is, however, safe for all drainage pipes and systems, including septic tanks.
Old 08-23-2010, 01:50 PM   #7
Rewards Points: 249
This stuff look familiar?
Old 08-23-2010, 07:05 PM   #8
Very. They also sell a powdered form. Has worked great when I needed it, but is still not a cure-all.
Old 08-24-2010, 08:39 AM   #9
Rewards Points: 249
Got that stuff last night and did one treatment of it. Haven't run washing machine to see if it did anything. Noticed the kitchen sink burping/gurgling a little when the dishwasher ran last night. Nothing came up. Might I be at the point where I call a professional? I really have no desire to rent a snake and attempt to clean my main line (I know, this is quite blasphemous on the DIY forum). Anyone know what I may expect to pay? 100? 200? 300? More?
Old 08-24-2010, 09:08 AM   #10
I cannot blame you for not wanting to get into a main line augering. Some work is best left to the Pros. Probably talking around $200, depending on how long the company is there.
Old 08-24-2010, 09:49 AM   #11
Rewards Points: 249
I'm going to climb on the roof again tonight or tomorrow, weather depending, and shove the hose down the vent to check it. When I looked at it, I could only see about 3 or 4 feet down before it had a 45 degree elbow or something. Might as well try everything.
Old 08-24-2010, 10:01 AM   #12
Is everything PVC ?
I had a drain problem in the basement
Two problems...PVC line was going all the way across the basement to the main pipe
So crud was building up & it could not handle the washer & sink combined
The 2" PVC was replaced with 3" PVC...problem solved
Checking further the stack was CI
It went from 2" in the basement thru the 2nd floor & 3-4" out the roof
In the basement it was clogged almost solid for maybe 3-4'
It was all cut out & replaced w/PVC
Old 08-24-2010, 10:37 AM   #13
Rewards Points: 249
From what I can see, its all PVC. Every drain I see coming from a toilet, the main stack, sinks, showers, etc has been PVC.
Old 08-24-2010, 10:53 AM   #14
Rewards Points: 249
Also something I should note, there is a floor drain in the laundry room that does NOT back up when the washer drains. From what I can see, it looks like the floor drain is after the washer/sinks/shower all connect, if it is even in the same branch. I'll try to get some pictures tonight.
Old 08-24-2010, 11:13 AM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 818
Durt, If your DW is draining ok and not backing up the basement shower I think your blockage is in the branch piping and not your mainline. You also said the basement FD is ok. Is that downstream from the shower? I think you need to use a mini jetter on the laundry/shower line. Or if you have a 3/8 cable, put a small bend in the first couple of inches. This will help scourer the pipe and grap lint/hair. If the pipe is sludged, if will act like a straw in a milkshake. Once you pull the cable out it will block again. A jetter will push the sludge away. Might get messy though.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Basement Shower Backup robbdc Plumbing 0 12-15-2009 08:22 AM
Washer Drain Backing Out with debris-HELP!!! CaliMom Plumbing 2 03-09-2009 05:36 PM
How to break the concrete for basement shower drain? epeterson777 Plumbing 2 01-18-2009 05:25 PM
shower in basement slab philip96 Plumbing 2 06-15-2008 09:46 PM
